Gallery
Gallery
165/170/175 Rebuilds
First aquasport, 87' 170 striper rebuild
Topic: First aquasport, 87' 170 striper rebuild (Read 13129 times)
April 04, 2008, 08:46:27 PM
jdupree
Reply #15 on:
April 04, 2008, 08:46:27 PM »
I think this boat is a 1988 based on the 2 tone hull color and deck color. My 1988 looked almost identical.
John L. Dupree, III
AQABLA84E999
Member #257
April 04, 2008, 11:58:10 PM
ANTIBLING
Reply #16 on:
April 04, 2008, 11:58:10 PM »
yeahhhhhhh my dad and I were also questioning the year. I bought the boat from my girlfriends dad and he insists its a 78 but I have yet to get over to his house and sign the papers over and whatnot...
87\' 170 striper
April 05, 2008, 09:29:40 AM
Mechanical Master
Year
Reply #17 on:
April 05, 2008, 09:29:40 AM »
You can tell the year from the HIN - Hull Identification Number. The codes are described at the following website:
http://www.boatsafe.com/nauticalknowhow/hin.html
See ya on the water!
April 05, 2008, 12:45:07 PM
Miguel
Panama
Reply #18 on:
April 05, 2008, 12:45:07 PM »
I bet it is > 1985
Miguel
[/url]
April 05, 2008, 02:42:33 PM
ANTIBLING
Reply #19 on:
April 05, 2008, 02:42:33 PM »
1987.
went and picked up the title today. The original owner bought it out the door for $9475 in 1987 with a 85 suzuki. I even have the original brochure for all the models in 87' lol the 17 is described as a 'Bass hunting machine' LOL
anyways got all the non-skid sanded off.
I dont know if I need to grind these out and fill or just roll a coat of gelcoat over problem areas in addition to the final coat of gelcoat
87\' 170 striper
April 29, 2008, 01:30:52 PM
ANTIBLING
Reply #20 on:
April 29, 2008, 01:30:52 PM »
update. boat is at my dads friends shop and hes going to help me out getting it done. decided on drilling holes in the transom, filling it with filler epoxy, and glassing it back over. and then make a metal bracket to fit where the motor will be attatched.
bluedyed and sanded the whole deck and gunnels with 80 grit.
should be molding a new console this weekend hopefully and my leaning post should be here tomorrow.
slowly but surely
87\' 170 striper
April 29, 2008, 01:42:05 PM
Marcq
Reply #21 on:
April 29, 2008, 01:42:05 PM »
Why are you drilling holes in the transom ? just curious
Marc..
April 29, 2008, 07:16:42 PM
ANTIBLING
Reply #22 on:
April 29, 2008, 07:16:42 PM »
because it is soft to the touch in a 10 by 10 square, so we have been trying to dry it out and then we are going to put in a bunch of filler epoxy through the holes to stiffen it up. call it a half ass fix, but it should last for a few years.
87\' 170 striper
April 29, 2008, 07:42:38 PM
Marcq
Reply #23 on:
April 29, 2008, 07:42:38 PM »
Not sure if it's going to help but if you drill the holes sideways maybe !!
Marc..
May 02, 2008, 09:34:18 PM
haleraiser2
Reply #24 on:
May 02, 2008, 09:34:18 PM »
AB can you give me dimension of the fuel tank? Is it a belly tank or flat bottom? I have the same year model that the owner before removed and does not have anymore!
May 03, 2008, 07:28:35 PM
ANTIBLING
Reply #25 on:
May 03, 2008, 07:28:35 PM »
i forgot to check today but I can sometime monday probably.
Got my leaning post in the mail and am VERY happy with it, also found a decent console to use in my buddys shop.
Deck and gunnels are ready for primer, should spray on monday or tuesday.
87\' 170 striper
May 07, 2008, 07:03:40 PM
ANTIBLING
Reply #26 on:
May 07, 2008, 07:03:40 PM »
sprayed the problem areas and main deck with awlgrip highbuild today. already looks better to me! no more spider cracks :)
ill go back tomorrow to blue dye and sand all the highbuild. then hopefully get the whole interior and gunnels primed this weekend.
87\' 170 striper
July 07, 2008, 12:44:47 AM
ANTIBLING
Reply #27 on:
July 07, 2008, 12:44:47 AM »
I want to flip the boat over and get the hull and topsides done, what would be the easiest way to do this? suggestions?
87\' 170 striper
September 10, 2008, 07:52:56 PM
ANTIBLING
Reply #28 on:
September 10, 2008, 07:52:56 PM »
I wanted to get rid of it then decided to change my mind. Im going to cut the cap a foor in from the transom and pull out the transom this weekend. Any tips or tricks before I tackle this?
87\' 170 striper
September 10, 2008, 09:06:50 PM
compcrasher86
Reply #29 on:
September 10, 2008, 09:06:50 PM »
Wish I could offer advice, but thanks for holding on to it, I wanna see what she'll look like when shes finished
Stock 1973 222 Open Fisherman
"Floor it"
