191 Rebuilds
Aquasport 19-1 Osprey rebuild begins
Topic: Aquasport 19-1 Osprey rebuild begins (Read 4726 times)
January 03, 2012, 10:23:19 PM
Read 4726 times
Defender
January 03, 2012, 10:23:19 PM »
Hi everyone so the weather in PA has turn cold I mean freezing cold todays high 13 degrees so I have torn the floor and the foam that is not in the stringers out of the boat. Luckly she fits in my heated garage.
Know the fun begins I removed some samples of foam out of the hole they used to fill the stringers and found between 1/2 and 1 inch of complete water saturation and all the foam to be damp any advise on drying the foam or full removal of the foam. Recomedations for replacement foam, would you foam the whole underdeck Aquasport only foamed the stringers and 2 of the 4 center sections and non of the outer sections.
Second question the floor was only 3/8" thick exet for the casting platform was 1/2" stay should I go to half inch all around and syn core recomendations
Third gas tank above or below deck
Thanks for the help I sure I will need lots of suport
January 03, 2012, 10:54:35 PM
Purgatory
Re: Aquasport 19-1 Osprey rebuild begins
January 03, 2012, 10:54:35 PM »
We welcome you here Defender! Thanks for your membership.
Cut off the very tops of the stringers in a workmanlike fashion with regard to the rebuild to come. Dig out ALL of the wet foam. Allow the stringers to dry thoroughly at this point. Get the inside of the stringers clean and dry. Leave her inside.
What year is she?
Your current floor is 1/2 inch plywood, glassed both sides. You will receive good advice on replacement.
Your new tank will go beneath the floor, between the stringers. Here too you will also receive good advice.
Welcome!
January 07, 2012, 07:02:04 PM
Defender
January 07, 2012, 07:02:04 PM »
Well got all the foam out of the stringers tomorrow I need to fix a few spots in the stringers anyone have sugestion or the type of foam to use.
January 07, 2012, 08:11:02 PM
Purgatory
January 07, 2012, 08:11:02 PM »
Four to six pound density closed-cell pourable foam should work nicely. Watch it tho...a little goes a long way.
Try and get her pretty level before the pour
January 08, 2012, 02:01:13 AM
Defender
19-1 rebuild
January 08, 2012, 02:01:13 AM »
Here are some pictures of my 19-1 rebuild
January 08, 2012, 01:12:52 PM
Defender
Re: 19-1 rebuild
January 08, 2012, 01:12:52 PM »
So I reliezed the first set of pictures wouldn't open so is new ones hope you enjoy
Makey Magic
January 08, 2012, 07:44:28 PM
Re: 19-1 rebuild
January 08, 2012, 07:44:28 PM »
Your pics can be up to 800x600. The you copy the "IMG" code - typically the only one showing under each pic, then paste that into the post and your pic will appear.
January 08, 2012, 10:08:22 PM
gman 82 aquasport
Re: 19-1 rebuild
January 08, 2012, 10:08:22 PM »
Your about right where I am in my rebuild, I used an angle grinder with a metal cutoff blade (thin) and cut the tops of the stringers about 3/4 inch down, this let me be under the top edge of foam a little bit, cut it all the way aroun then just lightly pried it off..used a sharpshooter shovel to remove foam, fit in stringers real well..your side pieces may be a little more involved, but whatever way you do it just make it easy to reglass the stringer lid back on, since I will raising my floor 3/4 in I am raising top height of stringers the same....good luck, she'll be a sharp boat when your done..
1982 19-6 Osprey
1992 Johnson 150
"THERAPY"
Member # 2331
January 23, 2012, 04:45:17 PM
Defender
Re: 19-1 rebuild
January 23, 2012, 04:45:17 PM »
New foam is curing time to close up the stingers and start the floor.
Anyone have any opions on if I should pull the gunnel liner and attach my new floor right to the hull or leave it and glass the floor into the gunnel. Planning on makeing the floor from 1/2" coosa bluewater 26 and biaxle 2 layers of 1708 (17 oz DB w .75 oz. mat) and 2 layers of 7781 (8.9 oz. 0/90 glass) on the top and one of each on the bottom
January 23, 2012, 08:12:04 PM
dirtwheelsfl
Re: 19-1 rebuild
January 23, 2012, 08:12:04 PM »
well pulling th eliner and glassing to the hull would be the best, strongest way. youll have some work to do where the cap meets the transom when you cut it off. if youre dead set on putting the liner back in, you could tab it back to the floor after its in. id just put one layer of 1708 top n bottom, with your layer of cloth over the biax on top. wet on wet if you can...
January 23, 2012, 09:12:02 PM
Purgatory
Re: 19-1 rebuild
January 23, 2012, 09:12:02 PM »
Good advice. If you do go back with the old liner (a money saver) make sure that you have plenty of gunnel support. As has been pointed out....the old teak rodholders were basically the only gunnel (deck cap) support on that long run.
If you want to avoid knees...as shown on the recent pics here of the Seamark 21....you can glass-in blocks at the liner top beneath the gunnels.
If you choose this method....glue the liner to the hull side with 5200. Done deal, very strong. Prevents chatter too.
February 15, 2012, 09:21:01 PM
pvmacguy
Re: 19-1 rebuild
February 15, 2012, 09:21:01 PM »
Defender,
I also have a 19-1 with the same front platform and hatch setup. Are you going to rebuild yours in the same fashion it was? If not, would you be interested in selling the hatches for the front? I need a right side replacement mine rotted and cracked in half.
Thanks!
February 16, 2012, 10:32:41 AM
Defender
Re: 19-1 rebuild
February 16, 2012, 10:32:41 AM »
My hatches are both badly cracked and full of water but I am planing on making new ones.
February 16, 2012, 06:34:13 PM
rob9
Re: 19-1 rebuild
February 16, 2012, 06:34:13 PM »
Great start! keep us updated with some pics!
March 13, 2012, 03:10:09 PM
Defender
Re: 19-1 rebuild
March 13, 2012, 03:10:09 PM »
191 Rebuilds
