Author Topic: NEED HELP...calculate center of gravity on 246 CCP  (Read 782 times)
November 02, 2007, 10:30:34 PM
Read 782 times
CKP
    • http://lifecycletechnologypartners.com/index
« on: November 02, 2007, 10:30:34 PM »
Should the center console be moved forward after an armstrrong bracket and twin four strokes are installed?
November 03, 2007, 09:24:51 AM
CG
« Reply #1 on: November 03, 2007, 09:24:51 AM »
The big CCPs were designed for twins weighing around 400 lbs each.  How much flotation does the Armstrong bracket provide?  You can do the math, but take the weight of your new engines and subtract the floation from the bracket, and that give you about the net on the back of the boat.
I would guess that the console can stay where it is, but I would move batteries up under the front of the console, and not put a big baitwell all the way to the stern...  Just my $.02...
