Author Topic: 1990 222 ccp switch panel wanted!!!  (Read 390 times)
June 23, 2015, 10:44:25 PM
Read 390 times
Adam927
« on: June 23, 2015, 10:44:25 PM »
Does anyone know if I can get a replacement switch panel for my 90 ccp? Original equipment? I already put a different one on it but I would like to go back to original.
June 24, 2015, 08:54:04 AM
Re: 1990 222 ccp switch panel wanted!!!
« Reply #1 on: June 24, 2015, 08:54:04 AM »
My guess is you won't find an original unless someone is parting with it.
Did it look something like this one (4th pic down in post)?
http://classicaquasport.com/smf/index.php?topic=3847.msg25336#msg25336
June 24, 2015, 08:56:54 AM
jdupree
« Reply #2 on: June 24, 2015, 08:56:54 AM »
That will be most likely hard to find.  The original switch panel was mounted in a recessed plastic housing.  They usually didn't last long.  I never liked the recessed switches on mine because they were hard to see.  I would just custom make something if it were mine.  Here is what I did.
This is what I had and most likely what you had.
Here is what I did.
Let me see if I still have the original plastic insert.  You might be able to use it as a mold to make a new one.  I doubt I have it but I will check.
John L. Dupree, III
AQABLA84E999
Member #257
June 24, 2015, 10:02:22 AM
Adam927
« Reply #3 on: June 24, 2015, 10:02:22 AM »
 That is the one.
 John
 I like the switch panel you made. I put one in that is similar but it is not sitting flush like yours. Water gets behind there in the rain and makes my lights come on. So I have to make sure my battery switch is off. LOL Need a better design.
June 24, 2015, 10:07:22 AM
jdupree
« Reply #4 on: June 24, 2015, 10:07:22 AM »
I made mine out of starboard.  It is not completely flush so I shot a bead of white silicon around it to seal it.  That has kept it dry.
John L. Dupree, III
AQABLA84E999
Member #257
June 24, 2015, 10:48:43 AM
« Reply #5 on: June 24, 2015, 10:48:43 AM »
Chris made his own and it came out like a factory one. Not too hard to do with a fiberglass.
http://classicaquasport.com/smf/index.php?topic=4582.msg126185#msg126185
