Hull Cleaning Solution
Topic: Hull Cleaning Solution (Read 287 times)
April 08, 2021, 08:07:27 PM
Read 287 times
boatnamesue
Jason
April 08, 2021, 08:07:27 PM »
Can anyone recommend a spray-on wipe-off solution good for removing the layer of grim on the hull underside? I'm pretty certain the bottom paint is white and not that tan color lol. Many thanks!
Jason
1976 AS 170
1998 S115TLRW
April 09, 2021, 11:21:12 AM
Re: Hull Cleaning Solution
April 09, 2021, 11:21:12 AM »
RustAid aka oxalic acid aka Starbrite Teak Brightener.
https://www.lowes.com/pd/RustAid-1-Gallon-Rust-Remover/4558106
Spray it on. Make sure to wet the entire surface, give it a minute or two then rinse it off with a hose. Keep it off the trailer or rinse it quickly if you get it on it. It tends to oxidize aluminum.
I get a lot of tannin stains in this portion of the Gulf along with the standard waterline stains. This stuff works very well on this as well as the occasional rust one finds on "stainless" fittings and will make teak trim (after cleaning) look brand new.
April 09, 2021, 12:04:08 PM
boatnamesue
Jason
April 09, 2021, 12:04:08 PM »
Awesome, thanks bud!
Jason
1976 AS 170
1998 S115TLRW
December 23, 2022, 08:59:20 PM
cryder
5618183858
December 23, 2022, 08:59:20 PM »
I've been trying barkeepers friend. Stuff works great and it's cheap.
Chris
