Plumbing
2004 215 osprey anchor locker drain
Topic: 2004 215 osprey anchor locker drain (Read 400 times)
January 12, 2021, 06:05:59 PM
Read 400 times
Joecephus1959
January 12, 2021, 06:05:59 PM »
My anchor locker plastic thru hull drain has broken off and i Can't find a replacement. I am hoping someone can help me find one...Thanks
January 12, 2021, 06:18:51 PM
Re: 2004 215 osprey anchor locker drain
January 12, 2021, 06:18:51 PM »
Does it look similar to this type?
https://www.wholesalemarine.com/t-h-marine-thru-hull-fittings-straight-white.html?gclid=Cj0KCQiArvX_BRCyARIsAKsnTxN-h5VpIHF-oCP4a6ubNd_noWm55ieuZr7Gx6s2-KaMDN0eBiKaFbYaAi6lEALw_wcB
January 12, 2021, 07:10:41 PM
Joecephus1959
January 12, 2021, 07:10:41 PM »
No it is one unit with the clam shell top.. the hole opening that the thru hull goes in is 3/4 inch...I hope you can see the one in the photo above the bow catch. the pic size is too big ...won't send
January 12, 2021, 08:39:30 PM
January 12, 2021, 08:39:30 PM »
Try reading this carefully.
Easiest way to post ANY SIZE FILE photo. The Forum does all the necessary sizing from your raw data.
I apologize but without the photo, I'm not sure what you're trying to find.
Plumbing
