Aquasport Model Rebuilds, Mods, Updates and Refreshes => Osprey Style Hull Rebuilds => 22-2 Rebuilds => Topic started by: Cjarreola on September 13, 2020, 12:47:48 PM
Just wanted to share the beginning of what will be a long journey. Considering that this is my first time restoring a boat, I will be leaning on many on this forum who have a vast amount of experience and knowledge to help make the right decisions.
Currently I am in the stripping down process as I access the work that will need to get down. Stay tuned as I post more pictures with questions to follow.
Any advice that you would give me for taking out the floor and transom?
If you want to post a pic when you talk about your boat, which you should, follow the instructions here http://classicaquasport.com/smf/index.php?topic=12725.0 - don't attach them - you are limited by file size. Uploading them into your "member gallery" is better for viewing. You can also rotate them if needed, in the gallery.
Thank you
Good luck and ask away. For the floor and transom most people start with a circular saw set just deep enough to get through the floor, and almost all the way through the transom. A sawzall, jigsaw, oscillating tool, angle grinder with a diamond wheel and chisel will usually take care of the rest.
