Author Topic: ‘77 Aquasport 170  (Read 319 times)
April 21, 2024, 09:34:12 AM
Read 319 times
Mfolsom
‘77 Aquasport 170
« on: April 21, 2024, 09:34:12 AM »
I am looking for advice on the way the motor is mounted on mine.
Is this a problem? Should I lower it or add a shim or just leave it there?  This is the way I received it.
https://classicaquasport.com/smf/index.php?board=28.0
April 21, 2024, 01:57:59 PM
Re: ‘77 Aquasport 170
« Reply #1 on: April 21, 2024, 01:57:59 PM »
Seems the anti-cavitation plate is even with the bottom of the hull so I think it is good.
Also, remember if using a phone to take pics, to hold the phone horizontal with the lens to the left. If you hold the phone vertical, the pictures post like the one above.
April 22, 2024, 11:40:59 AM
Mfolsom
« Reply #2 on: April 22, 2024, 11:40:59 AM »
What do people do with the fuel tank coffin if not using it for a fuel tank?  With the console and a bench seat over it, that makes it somewhat inaccessible. Looking for ideas.
April 22, 2024, 01:25:26 PM
« Reply #3 on: April 22, 2024, 01:25:26 PM »
Unless you have issues with the way it runs, i would leave the motor where it is. Typically as Rickk mentioned, the cavitation plate is at the same level as the bottom of the hull at the transom. Regarding the fuel tank coffin, not sure why one would scrap it out of the boat. It serves the purpose well to keep the fuel tank off the bottom of the bilge area a few inches and out of the elements. The hatch setup is nice to get to the tank in the future if and when it fails.
1971’ Flatback 222 - SOLD
1972' 240 Seahunter - SOLD
April 22, 2024, 07:25:08 PM
Mfolsom
« Reply #4 on: April 22, 2024, 07:25:08 PM »
There was no fuel tank when I got the boat.  The filler hose is all rotted away and the hole for the mounted cap is too large for the one that was rattling around in it.
April 23, 2024, 03:02:39 AM
« Reply #5 on: April 23, 2024, 03:02:39 AM »
Post some better photos showing what your talking about.
April 23, 2024, 11:44:43 AM
Mfolsom
« Reply #6 on: April 23, 2024, 11:44:43 AM »
The fuel fill hose in the coffin
This cap has 3 hole mounting.  The boat had a 4 hole mounted one before.
I currently don’t even have a tank to put in the compartment, just the portable red plastic ones.
Everything I have photos of are in my gallery now.
April 23, 2024, 03:34:13 PM
« Reply #7 on: April 23, 2024, 03:34:13 PM »
The hoses were foamed in place which made them a pain to replace, especially if the deck is still in place. Make sure you run a vent tube also. Perko (and others) makes a fill cap with integrated vent. Check that out.
You can buy roll or squares of rubber to make your own  gaskets - https://www.amazon.com/Neoprene-Plumbing-Material-Leveling-Protection/dp/B0BTHH4V2B?asc_source=01HFY6QA52QM8M7ATBSHXHG6T4&tag=snx70-20
April 27, 2024, 08:34:25 AM
Mfolsom
« Reply #8 on: April 27, 2024, 08:34:25 AM »
I found a gas tank that fits.  I met the owner of Towboatus in Chattanooga and he had it posted on FB Marketplace for $75.  The tank dropped right in and the fill hole lined up with where the old one came in.  Now I have to dig that old hose out and replace it.
