Author Topic: 1974 Aquasport 22-2 Rebuild  (Read 9625 times)
August 05, 2012, 09:07:31 PM
Capt_E
Re: 1974 Aquasport 22.2 Rebuild
« Reply #15 on: August 05, 2012, 09:07:31 PM »
Motor off and bait boxes removed.
Something I found as being weird was a drain plug right in the middle of where the motor was mounted.  Is it just me or does that not seem right?
1974 Aquasport 22-2
August 05, 2012, 11:37:13 PM
« Reply #16 on: August 05, 2012, 11:37:13 PM »
My first 22-2 had three drain plugs, exactly where yours are.
August 06, 2012, 04:59:20 AM
« Reply #17 on: August 06, 2012, 04:59:20 AM »
I think you can see the evolution of motors on that transom looking at the holes that are filled.  The motors back in the year the boat was made were much narrower and you can see the holes get wider until the latest motor holes.
August 06, 2012, 08:53:40 AM
saltfly
« Reply #18 on: August 06, 2012, 08:53:40 AM »
My 72 19-6 has three drain holes. If you think about it. It made sense. These boats decks and drain well sit low. Soon three drain holes will help it drain faster. But you could also say. They let more water in. :thumright:
August 13, 2012, 08:06:37 PM
Capt_E
« Reply #19 on: August 13, 2012, 08:06:37 PM »
Finally got the boat to a buddies shop so the demo can start.  For now I will be attempting the demo on my days off when possible.
So the big question is, where do I start with the demo?  Anything in particular first, second, etc...?  What do I need to save or toss.  Any insight into this would be great, thanks.
1974 Aquasport 22-2
August 13, 2012, 08:29:30 PM
« Reply #20 on: August 13, 2012, 08:29:30 PM »
Take the floor out first. Set the skilsaw to 3/4 inch depth, leave a 1.5 inch lip on the hull sides; you can make a decision on this edge later on.
Leave the rear skin on the transom. Cut out the inboard fiberglass side of the transom.
Run a chalk line on both sides of the stringer tops, take a skilsaw and cut off the horizontal tops of the stringers. You want the very top cut, no more.
Take a machete and narrow shovel to the stringer foam, toss it and all of the plywood, including the transom plywood. Then get out the shop vac.
Recently the guys have sandblasted the interior hull at this point, rather than grinding old substrate. Darn good idea, a real time-saver, and they've been pleased.
There are many rebuilds here with great pics detailing what you have in front of you. She'll go smooth.
Best :thumright:
August 13, 2012, 08:36:32 PM
Capt_E
« Reply #21 on: August 13, 2012, 08:36:32 PM »
Thanks, I hope to start the process in a couple days.  I will post pics of the destruction, lol.
1974 Aquasport 22-2
August 13, 2012, 08:45:59 PM
« Reply #22 on: August 13, 2012, 08:45:59 PM »
Welcome to Itchy Town!  I know its summer and its smoking hot but a paper suit or even jeans and a long sleeve shirt will help keep the itchy dust off you.  Good luck!  :thumright:
Check out Aaron's tread.....   viewtopic.php?f=2&t=9497
August 13, 2012, 08:50:37 PM
Capt_E
« Reply #23 on: August 13, 2012, 08:50:37 PM »
Quote from: "Blue Agave"
Thats funny, the shop I dropped it at, the owner even said "let me know what size suit you wear."  Getting at the fact that the fun is about to begin.
1974 Aquasport 22-2
August 16, 2012, 02:03:49 PM
Capt_E
« Reply #24 on: August 16, 2012, 02:03:49 PM »
A little progress.  Got the console off the deck and gutted all the cables and wiring.
1974 Aquasport 22-2
August 16, 2012, 03:55:39 PM
Capt Matt
« Reply #25 on: August 16, 2012, 03:55:39 PM »
Just about power tool time. Block her up nice and level in a place you can do most of the build. I used styro blocks and wooden shims. You want to keep the original shape of the hull. Block her up as low to the ground as you can as you will be climbing in and out thousands of times.
Good luck
Capt Matt
Light tackle sportfishing
August 17, 2012, 12:23:29 AM
Necessary Evil
« Reply #26 on: August 17, 2012, 12:23:29 AM »
Taking out the deck really wasn't that hard, even though I am severely power tool challenged. Putting it all back together professionally was what made me balk. The supplies get very expensive at that stage and I just had to punt it to a pro. I do think that I saved a ton of dollars doing most of the demo myself though. That was just a matter of elbow grease, and kind of fun, in a medieval sort of way :)
Charlie
1976 22-2
Roll Tide!
October 11, 2012, 11:09:01 AM
Capt_E
« Reply #27 on: October 11, 2012, 11:09:01 AM »
A few progress update pics
1974 Aquasport 22-2
October 11, 2012, 11:42:59 AM
« Reply #28 on: October 11, 2012, 11:42:59 AM »
Progress! :thumright:
How itchy was deconstruction? :mrgreen:
October 11, 2012, 02:34:26 PM
fishinonthebrain
« Reply #29 on: October 11, 2012, 02:34:26 PM »
I still itch looking at all that and the mutiple sweat clothes under the nomex suit.
looks great though!  :salut:
1987 222CCP current rebuild.
