Author Topic: TAKING OUT FOAM IN STINGER  (Read 1108 times)
March 25, 2018, 10:22:10 AM
Re: TAKING OUT FOAM IN STINGER
« Reply #15 on: March 25, 2018, 10:22:10 AM »
Sounds like it will be an awsome build.  I look forward to following your work.
March 25, 2018, 10:28:16 AM
msteelman
« Reply #16 on: March 25, 2018, 10:28:16 AM »
 sense I'm not going to put foam in between the side of the hull and the side of the liner do you thing i should put 2 inch stiffeners  on both the hull and liner
March 25, 2018, 10:30:44 AM
« Reply #17 on: March 25, 2018, 10:30:44 AM »
You've got a good chance to look things over with the liner out, but some kind of stiffeners are probably a good idea to prevent oil canning.
March 25, 2018, 10:35:50 AM
msteelman
« Reply #18 on: March 25, 2018, 10:35:50 AM »
oil canning?
March 25, 2018, 10:43:26 AM
« Reply #19 on: March 25, 2018, 10:43:26 AM »
oil canning?
When you have flat surfaces.  You press on them and they flex like the bottom of an old time oil can.  If it can flex when you press on it, it will certainly flex as your boat travels over waves.
March 25, 2018, 02:08:27 PM
222 newbie
« Reply #20 on: March 25, 2018, 02:08:27 PM »
x2
JR
1970 22-2 Flatback  CC, T top, Mariner 135 Opti Max, Porta bracket.
