Aquasport Mechanicals - things that need a wrench, screwdriver or multimeter => Controls, Steering, and Trim Tabs => Topic started by: kevinr on April 25, 2020, 06:35:32 AM
What trim tilt assemblies...need part number(s)... fit a 1974 Evinrude model 115493b 115hp?
Marineengine.com has the part numbers.
I had found http://www.marineengine.com/parts/johnson-evinrude-accessories/index.php?year=1974&model=Electrical+1974§ion=Power+Tilt+Kit-70+Long%2C+85%2C+115+%26amp%3B+135+Hp&yid=34223&mid=34224&sid=35746
But all I see are parts - not the part number for the entire assembly. My motor didn't come with one and I'd like to add one. I've seen the cmc stuff - a little pricey.
Good luck with that. The trim system was from 1973 to 1977 as an accessory. You will need to hunt across the country for a complete unit. I had a complete assembly in stock about 20 years ago and sold it but even in those days it was rare that someone needed one.
will one from a 1976 135hp fit my 1974 115hp? if so, i may have found something local.
the answer (via a dealer) is yes - 76 from a 135hp will fit a 74 115hp.
There you go
unfortunately, what he had was tilt only (one ram). fortunately, i now know what i need is part #172859. let the search begin again.
Yep, broaden your search
1973- 1976 50, 65,70, 85, 115, 135 trim and tilt.
1977 55, 70, 85, 115, Not 140, was the first year on internal trim and tilt like the new 200 V6.
Those trim systems are out there, you just have to hunt freshwater inland.
that' the exact list i needed. im searching ebay, searchtempest (craigslist) and facebook marketplace. any other suggestions? if i run out of luck, i may do a CMC pt-130 if i can find one used at a reasonable price and get it to texas.
