Author Topic: Beginning my 1972 Semi-v 222 restoration  (Read 644 times)
September 13, 2020, 12:47:48 PM
Read 644 times
Cjarreola
« on: September 13, 2020, 12:47:48 PM »
Just wanted to share the beginning of what will be a long journey.   Considering that this is my first time restoring a boat, I will be leaning on many on this forum who have a vast amount of experience and knowledge to help make the right decisions.
Currently I am in the stripping down process as I access the work that will need to get down.   Stay tuned as I post more pictures with questions to follow.
Any advice that you would give me for taking out the floor and transom?
September 13, 2020, 02:31:20 PM
Re: Beginning my 1972 Semi-v 222 restoration
« Reply #1 on: September 13, 2020, 02:31:20 PM »
If you want to post a pic when you talk about your boat, which you should, follow the instructions here http://classicaquasport.com/smf/index.php?topic=12725.0  - don't attach them - you are limited by file size. Uploading them into your "member gallery" is better for viewing. You can also rotate them if needed, in the gallery.
September 13, 2020, 05:01:41 PM
Cjarreola
« Reply #2 on: September 13, 2020, 05:01:41 PM »
Thank you
September 15, 2020, 08:27:38 AM
« Reply #3 on: September 15, 2020, 08:27:38 AM »
Good luck and ask away. For the floor and transom most people start with a circular saw set just deep enough to get through the floor, and almost all the way through the transom. A sawzall, jigsaw, oscillating tool, angle grinder with a diamond wheel and chisel will usually take care of the rest.
