165/170/175 Rebuilds
Rainboat 170 - Rebuild Started
Topic: Rainboat 170 - Rebuild Started (Read 2165 times)
November 12, 2021, 01:25:17 PM
Reply #45
larsli68
Re: Rainboat 170 - Rebuild Started
Reply #45 on:
November 12, 2021, 01:25:17 PM »
Great job! Looking good!
January 18, 2022, 04:35:44 PM
Reply #46
Rainboat
Reply #46 on:
January 18, 2022, 04:35:44 PM »
I finally got back on the project a little bit. Put the rest of the deck in and ut a coat of epoxy on. Also ran a filet along the deck/gunwale transition so I can add some tabbing. I'm going to glass the deck. I'm curious how heavy folks usually glass the deck?
March 28, 2022, 04:59:45 PM
Reply #47
Rainboat
Reply #47 on:
March 28, 2022, 04:59:45 PM »
I took the gel coat off to take a better look at the hull and previous repairs. I have a couple of questions
It looks like I have to fill some areas to bring them level with the rest of the hull.
Do people usually fill with layers of glass or with fairing material then glass?
There are a lot of pinhole and small voids in the hull after sanding gel coat. Should I mix a thin slurry to fill? I'm thinking of adding a layer of glass to the hull after filling pinholes.
Are the lifting strakes hollow or solid?
Thanks,
N
March 29, 2022, 09:18:12 AM
Reply #48
AquasportEd
Reply #48 on:
March 29, 2022, 09:18:12 AM »
I dont have experience with this, but I would imagine you'd want to fill the holes first, then glass
How did you end up flipping the hull? Im not at that stage of my build yet, but ive been trying to come up with a good way for when the time comes...
March 29, 2022, 09:58:14 AM
Reply #49
Rainboat
Reply #49 on:
March 29, 2022, 09:58:14 AM »
To flip it I got it off the trailer onto pads on the ground. I then lag bolted two (three or four may be better) 2x8's to the top of each rail. Like two big thwarts at rail level where the liner attaches. Then six guys lifted and rolled it. I put some soft stuff under the rail and tried to get it over smoothly without letting all the weight sit on the gunwale. Seemed to go well. The epoxy cracked on some plywood (not deck) I had attached to the gunwale. Not too structural so I'll just filet back on. The guys lifted it up and I put horses underneath.
It was a little dicey but I think its all ok.
I should have taken pictures.
March 29, 2022, 12:38:53 PM
Reply #50
Reply #50 on:
March 29, 2022, 12:38:53 PM »
Cool rebuild. What are your finishes going to look like? Gelcoat or two part paint? I would say to fill all the pinholes with a thickened (cabosil) resin and then going over the hull bottom with a layer of 1708 glass and then mat for sanding smooth. I didn't catch if you went down to the bare inside of hull with 1708 like Rickk but if not this would make it extra strong. However, it might be difficult to get all the contours and radius around the lifting strikes just right. For larger than about 1/4 -3/8'' voids, I would taper/prep the void and lay up some glass.
1974' 240 CC -
1970’ Flatback 222 -
1981’ Osprey 22-2 -
1971’ Flatback 222 - SOLD
1972' 240 Seahunter - SOLD
March 30, 2022, 05:47:00 AM
Reply #51
Reply #51 on:
March 30, 2022, 05:47:00 AM »
When I ground down the bottom of my hull I found two big low areas by the ransom that were bowed up toward the hull, like a "hook" in the hull. It was like 3/8" so I decided to fill it in. I used various sized pieces of CSM and built it up and then faired all of that in.
July 05, 2022, 01:07:39 PM
Reply #52
Rainboat
Reply #52 on:
July 05, 2022, 01:07:39 PM »
A little more progress. Put a layer of 1708 on the bottom (didn't go too smoothly). Also put a skeg on the bottom. Skeg is Batu (mahogany) epoxy + filet + tab.
July 06, 2022, 05:54:13 AM
Reply #53
Reply #53 on:
July 06, 2022, 05:54:13 AM »
It will be interesting to see how that skeg affects the hull handling. The 170 handled fine in its original design - no sliding, turned fine. That skeg is very aggressive looking - I would think a 1/2" tall skeg would have done the trick.
July 09, 2022, 10:44:53 AM
Reply #54
Rainboat
Reply #54 on:
July 09, 2022, 10:44:53 AM »
I'll let you know. I have one on my other boat, works great. Easily modified.
N
