Aquasport Model Rebuilds, Mods, Updates and Refreshes > Express Fisherman/ Walkaround/ Explorer Rebuilds
1981 246xf listing
(1/1)
captaincahill8:
I have noticed that my boat lists to starboard a bit at standstill as well as when under power. I am re adding trim tabs this fall to fix this when underway but anchored or on a mooring the boat seems to list. Im wondering if this is just from the design of the boat? As the helm and a majority of the wiring and such goes up that side.
I am thinking about maybe adding some ballast to the port side to assist with this but wanted to get others thoughts as well!
Capt. Bob:
Here's a start. It's for a Genmar model but it gives some insight. Plus a few more.
http://classicaquasport.com/smf/index.php?topic=12393.msg125062#msg125062
http://classicaquasport.com/smf/index.php?topic=15231.msg149028#msg149028
http://classicaquasport.com/smf/index.php?topic=5617.msg37792#msg37792
http://classicaquasport.com/smf/index.php?topic=4938.msg31403#msg31403
Yes, you have a Hialeah hull which is slightly different in the in-hull drainage routes but the theory is the same. Hopefully you will get some ideas from these threads to help you look into the "why"
Good luck. :thumright:
captaincahill8:
Thank you Capt. Bob! I will do some more investigating, but the fix will most likely be to add some weight to the port side. Bilge seems to be fully dry as of now and I am getting the proper drainage but maybe not. Ill report back !
