Aquasport Model Rebuilds, Mods, Updates and Refreshes > Paints, topsides and bottom and Gelcoat Topics
Hull Repair
(1/2) > >>
umecheme:
So I finished my hull repair, sanded down the keel area, filled and epoxied new glass over the section of the keel where the PO had been beaching.  Now that the repair is finished, what's my best option?  I'll sand it down and do a little bit of fairing, but should I gelcoat over the repair?  I know I'm not supposed to use topside paint below the water line, but what if i'm going to be bottom painting over it?  Thoughts?  I'm reading up on it now, but haven't found a great answer.
Thanks, in advance!
-Mike
RickK:
Will it live on a trailer?
umecheme:
Its possible that it could end up on a mooring for a couple weeks a year....
wingnut:
Epoxy barrier coat (the gray stuff) followed by bottom paint would be a good option... I don't know that there's any reason to go down the cosmetic gelcoat route if you're going to bottom paint for aesthetics anyway. Barrier coat not a bad idea but might not even be necessary in your application. Glad to hear you're making progress!
RickK:
Here is what I did to my 170
https://classicaquasport.com/smf/index.php?topic=10101.msg129891#msg129891
[#] Next page
