22-2 Rebuilds
1977 22 -2 rebuild
Topic: 1977 22 -2 rebuild (Read 5978 times)
January 25, 2015, 09:21:53 PM
Read 5978 times
northfork
1977 22 -2 rebuild
January 25, 2015, 09:21:53 PM »
Well here we go. finally found what what is looking for. 1977 boat in ok shape. not to far away (200 miles) and priced good. Started to take apart andf think I have a plan as to how I want it to come out. I tried to up load picks not sure how that part works yet.
As of today pulled the deck, tank and all foam. Cleaned up alot of interior of the hull and cut out a template fornthe transome.
January 26, 2015, 05:19:03 AM
Re: 1977 22 -2 rebuild
January 26, 2015, 05:19:03 AM »
Congrats on the find.
Spend a few minutes looking at the instructions posted here to learn how to post pics.
January 26, 2015, 01:19:49 PM
northfork
January 26, 2015, 01:19:49 PM »
January 26, 2015, 01:31:28 PM
northfork
January 26, 2015, 01:31:28 PM »
June 15, 2015, 04:20:09 PM
northfork
June 15, 2015, 04:20:09 PM »
Glassed in the first two layers on the transom over melamine on the outside skin.
ADMIN EDIT: I fixed your pic for you
June 15, 2015, 05:13:57 PM
June 15, 2015, 05:13:57 PM »
Nice looking work
June 17, 2015, 12:32:50 PM
northfork
June 17, 2015, 12:32:50 PM »
Two layers of mat and 1708
Not to bad in the corners.
Question: How many layers of 1708 should I do before the core?
Thanks for any feedback
June 17, 2015, 01:19:09 PM
June 17, 2015, 01:19:09 PM »
Nice work
How thick is the old transom skin? You'll want to bring the top area up to the same thickness (make the inside of the transom all flat) before adding your coring. I would do 3 layers of 1708 with 4, 8 and 12" overlap. Seems to be the norm that I see here and what I did with mine.
June 17, 2015, 05:17:05 PM
Que Pasa
NorthEast
June 17, 2015, 05:17:05 PM »
Are you tabbing or running a full sheet of 1708 as the tab.
June 18, 2015, 01:09:12 PM
northfork
June 18, 2015, 01:09:12 PM »
Que Pasa
I'm doing both. Tab then full layer of 1708 that also overlaps the tab.
June 18, 2015, 02:15:49 PM
Callyb
MidWest
June 18, 2015, 02:15:49 PM »
You got some glassing skills, Sir!
Do you mind posting a quick drawing of your lamination schedule? I am not understanding what your're plan is....
Also, I left a reply to your PL question over on my thread.
Thanks!
Carl
___________________________
June 18, 2015, 05:21:24 PM
Que Pasa
NorthEast
June 18, 2015, 05:21:24 PM »
Sweet North I figured that's the easiest way. Will you wrap the core or just glass after your glue to the outer skin sets up.
June 19, 2015, 12:26:06 PM
northfork
June 19, 2015, 12:26:06 PM »
Que. I have 1 1/2" Cosa for the transom. I will do a layer of glass then bond to my skin. Which is done now. I am going to try to do that this weekend. Hey its going to be fathers day we should be able to work on our boats if we want. We will see how that goes.
June 19, 2015, 01:14:42 PM
northfork
June 19, 2015, 01:14:42 PM »
outer face of transom
four layers of 1708 with mat between each
June 19, 2015, 03:34:11 PM
June 19, 2015, 03:34:11 PM »
Looks good.
You can save your self some materials in the future, 1708 has mat sewn onto one side. That should be the side you mate to the cloth side on the previous.
If you're using 1708-DB (I think that is the part #) where it has no matt, disregard.
22-2 Rebuilds
1977 22 -2 rebuild
