165/170/175 Rebuilds
Fishbox pumpout where is the pump?
Topic: Fishbox pumpout where is the pump? (Read 517 times)
August 22, 2020, 04:17:28 PM
Read 517 times
TopherMichael
August 22, 2020, 04:17:28 PM »
My '99 175 has a switch on the dash "Fishbox Pumpout", however nothing happens when toggling the switch.
What is the fishbox and did the boat come with a pump connected to this switch from the factory?
1999 Osprey 175
August 22, 2020, 10:02:32 PM
Re: Fishbox pumpout where is the pump?
August 22, 2020, 10:02:32 PM »
98 catalog shows an insulated fishbox with pump out (#2 in lower left of photo).
You can see the access plate in the bottom of the box. I would guess that if you have a pump, it would be located under that plate.
August 24, 2020, 09:52:29 PM
TopherMichael
August 24, 2020, 09:52:29 PM »
Thanks!!
1999 Osprey 175
August 31, 2020, 09:31:41 AM
TopherMichael
August 31, 2020, 09:31:41 AM »
Found the pump and several other items. Appears that a previous owner used that cavity as a storage area for flares, water bottles, sun tan loation and bug spray. God knows how long any of that stuff was sitting for yuck!
1999 Osprey 175
