Flatback 22-2 Rebuilds
71 22-2 Flatback Re-build Watch and Comment Please
12
13
14
15
Topic: 71 22-2 Flatback Re-build Watch and Comment Please (Read 13861 times)
November 30, 2018, 11:05:06 AM
Reply #180
Re: 71 22-2 Flatback Re-build Watch and Comment Please
Reply #180 on:
November 30, 2018, 11:05:06 AM »
Thanks! That's very cool of you to offer it but I think I am wanting to go with a new one.
December 13, 2018, 11:04:06 PM
Reply #181
Marcel4t
Reply #181 on:
December 13, 2018, 11:04:06 PM »
Quick update, I picked up my center console, it's in back of my van so no pics. I am prepping the stringers to refoam, but before I do, I want to tab in fresh glass on the insides of the stringers. I will fill in the inside corners of the stringers with thickened epoxy, then lay up 1708 on the hull and up about 3-4" of the stringer walls. The stringers are not held on that strongly to the hull, mostly held on with globs of resin. This should stiffen them up really good.
I also cut out the center front stringer, to give me more storage space and make it easier to drain water from one compartment as opposed to 2. I will lay up a few layers of glass and put a couple bulkheads to stiffen the area back up.
January 02, 2019, 01:19:11 PM
Reply #182
Marcel4t
Reply #182 on:
January 02, 2019, 01:19:11 PM »
Got my leaning post and CC in!! Super excited! My old T-Top ALMOST fits the CC too, its about 2" to big on the bottom legs (Top attached to console at all its points) Not sure if I can get someone to bend them to fit??
January 02, 2019, 01:54:29 PM
Reply #183
Reply #183 on:
January 02, 2019, 01:54:29 PM »
Nice - I'm sure someone could bend that in for you.
January 02, 2019, 03:48:18 PM
Reply #184
Reply #184 on:
January 02, 2019, 03:48:18 PM »
Looks like a nice combo. Where did you end up getting them from?
January 02, 2019, 04:36:44 PM
Reply #185
Marcel4t
Reply #185 on:
January 02, 2019, 04:36:44 PM »
Found a place 1 mile away from me that sells them, for cheaper than the factory too. Since it was right there I saved on shipping by picking it up. Cody is the guy I dealt with, nice guy.
https://www.marinefiberglassdirect.com
January 02, 2019, 05:50:43 PM
Reply #186
Reply #186 on:
January 02, 2019, 05:50:43 PM »
Cool. All that running around and it was right under your nose. Glad you got a deal
January 02, 2019, 06:11:27 PM
Reply #187
theFunsmith
Reply #187 on:
January 02, 2019, 06:11:27 PM »
Those look killer. I am excited for you.
January 07, 2019, 08:29:39 PM
Reply #188
Marcel4t
Reply #188 on:
January 07, 2019, 08:29:39 PM »
So I have been in analysis paralysis for weeks now. I am so torn on whether I should stick with the stringers I have, or start fresh. The more I look into it, the more I am leaning towards ripping everything out and starting fresh. I found a stringer in the front port side that was totally not attached to the hull, it was just floating. There are cracked stringers in the area to. I could glob some thickened epoxy under and glass it down. But as I walk around the hull, i can feel it has some flex. Id like to be able to lay some new glass over the whole hull. But doing this means I am committing myself to a whole lot work, with grinding out the old stringers. But, in the end I will feel confident it was done right. Can anyone suggest why I should try and just use my old stringers??
January 07, 2019, 10:04:32 PM
Reply #189
Reply #189 on:
January 07, 2019, 10:04:32 PM »
I am lucky in that my stringers were in really good shape and I didn't need to make that decision, but if I did they would've had to have been really really bad before I would have considered ripping them all out. There has to be some good glass still in them, right? Plus you already have the perfect template already there. Can you weigh that front stringer back down flat or is the hull twisted or flexed at all? If you can, then I would think it would be easiest to glue it back down with some thickened epoxy and then run a couple of tabs down the full length of them. Then cover it all with another layer or two. Even then you would still end up using a lot less material, not to mention the time you would save in grinding and remeasuring everything. Are you still planning to foam them? That will add a lot of rigidity back to the hull as well.
March 13, 2019, 07:15:04 PM
Reply #190
Marcel4t
Reply #190 on:
March 13, 2019, 07:15:04 PM »
Newest Vid in the build!
https://youtu.be/H4FxVps2A_E
March 13, 2019, 09:57:37 PM
Reply #191
Reply #191 on:
March 13, 2019, 09:57:37 PM »
Good to see you back at it.
March 14, 2019, 05:51:35 AM
Reply #192
Reply #192 on:
March 14, 2019, 05:51:35 AM »
For your T-top I would look for some round aluminum stock the same diameter as the flange that is short of the console (so maybe it is 2" or 2.5"?) and cut it to length so it fills the gap. Then drill it to match the holes in what you have and use longer bolts.
March 18, 2019, 09:17:37 PM
Reply #193
Marcel4t
Reply #193 on:
March 18, 2019, 09:17:37 PM »
What are your thoughts on having the T Top only attached to the console and not the floor? It was like that on the last boat, so Im guessing it works? But someone commented on my vid saying that it was a bad idea. I plan on using both screws (on outside) and tabbing (on inside) the console down to sole.
March 19, 2019, 06:16:08 AM
Reply #194
Reply #194 on:
March 19, 2019, 06:16:08 AM »
The console needs to be stout and well attached, but rolling the legs into the console saves a lot of space on deck.
I had Birdsall roll my rear legs into the console and tuck my front legs into the floor in front of my console. My coffin box will fit between the front legs.
12
13
14
15
