Well, here's the bleeder fitting in all it's glory... :x
Don't see too many of these around anymore...
Chris,Have you thought of "adapting" out of the existing port, and then installing a newer bleeder assy. You said one of the prts has a broken fitting in it? if the other hole has good threads, a local hyd shop might be able to make a suggestion, by matching up the thread pitch for a female adapter, then inserting some type of bleeder instead of the style you currently have set up. Just a thoughtMarc
So you are thinking a close nipple to a bleeder cap ? Like a water shut off valve set up? do they make a nipple that smalll? Okay have to stop saying nipple...does that follow your train of thought?
Quote from: "flounderpounder225"Chris,Have you thought of "adapting" out of the existing port, and then installing a newer bleeder assy. You said one of the prts has a broken fitting in it? if the other hole has good threads, a local hyd shop might be able to make a suggestion, by matching up the thread pitch for a female adapter, then inserting some type of bleeder instead of the style you currently have set up. Just a thoughtMarcSo you are thinking a close nipple to a bleeder cap ? Like a water shut off valve set up? do they make a nipple that smalll? Okay have to stop saying nipple...does that follow your train of thought?
Quote from: "Whitewater"Quote from: "flounderpounder225"Chris,Have you thought of "adapting" out of the existing port, and then installing a newer bleeder assy. You said one of the prts has a broken fitting in it? if the other hole has good threads, a local hyd shop might be able to make a suggestion, by matching up the thread pitch for a female adapter, then inserting some type of bleeder instead of the style you currently have set up. Just a thoughtMarcSo you are thinking a close nipple to a bleeder cap ? Like a water shut off valve set up? do they make a nipple that smalll? Okay have to stop saying nipple...does that follow your train of thought?This is exactly what I am thinking, it replaces the entire bleeder, you would have to disassemble the ram because of the shavings caused by drilling the existing hole out. But this would solve your problemhttp://www.levineautoparts.com/bleederrepair.html
Do you know the thread size? If not head to your local Ace hardware store and spend some time in the fastener section trying different nuts to get the right fit.
Chris that looks like almost the same type of bleeder screw as there is on some types of furnace burners.. If you have an old geezer plumbing and heating guy he may be a good source. The young guys may not have seen enough to be able to help..Do you know the thread size? If not head to your local Ace hardware store and spend some time in the fastener section trying different nuts to get the right fit. It looks like the end of the bleeder slides up into a seat to make a seal. If you can't find something to make the seat on the inside you may want to try a correctly sized stainless machine screw with a washer and an o ring underneath the head. If the diameter of the o ring is big enough you may get a good seal. The steering system is relatively low pressure (not 3000psi) and getting a seal should not be that hard. Before I would go drilling out threads of just the o ring doesn't work, I would try putting a "flat" across the hole with a file to make a better seat for the o ring, you might have ORB fittings for the hoses, if you do, that's the idea. In the ORB fitting, o ring squash makes the seal not threads..If you can make an o ring seal, then bleading is easy, leave the screw loose and make a big mess till the air is out then tighten her up and go boating.. No need to drill out for a NIPPLE if this works..
