Hello, I have read over this forum for some time now, I finally registered. I have been wanting a 22.2 for a long time and I now have 2. 1 is a 72 22.2 semi v the other is an inboard semi v. I have started on the inboard first because the floor was already ripped out of it by someone else. I will post some pics as i go along. I have a few questions, If I were to mold the original floor cap and the top cap would anyone be interested in buying them for their boat? Also if I make a mold of the floor and cap could i get in trouble for selling them (Because of someone elses design)???? I work at a family business that has all the equipment to make these rebuilds alot easier. One of the boats that I have has a perfect floor which would be great for making a mold off of. Please share your views on these subjects.
AKbridge, I am redoing my boats for two reasons 1: To make sure there isnt any rot threw out the hull. 2: To make a full transom for a porta bracket. Either way you will have a like new boat. Just my thoughts. Maybe it will help other people too. I am right off of Ewell Road. We are close to each other. What boat doyou have?
I have three boats that are going to need a floor. I am going to make a mold regardless of cost. I am not sure how they attached the splash to the transom because I cant find a seam. If I make a mold for a splash that will go to th top of your transom (if you have a full transom) you can just drop in. If you have an open transom you can drop it in then cut to the heights you need. Then glass it to your transom. The cost of just materials for making a splash should not go over $1,500 bucks each. And that is with deck lids and new deck. If you are going to spend the time and money to put a new floor in you should just buy the floor and set it in your boat instead of doing all of that hand fitting and having a floor without the original crosshatching. Just my thoughts. We will see how it turns out. I have alot of other ideas to.
