Any of you zuke owner have parts issues? I only ask because my guide buddy on Captiva just waited 8 weeks for a part for his 175 zuke that kept him off the water, luckily he borrowed a mutal friends spare boat.Capt Matt
Here is my first report on the new Mercury 150 4 stroke I just put on my 1977 FF 222. It replaces a 1997 Mariner 175 EFI. The Mariner would do 43.5 mph at 5100 and the new 150 does 40mph at 4800 with the same prop, which is a Mercury 3 blade 14 by 19. I plan to re-pitch the prop to 17 in. when I pull the boat in April.She comes out of the hole just fine by my standard. The rigger from Walker Marine on Marco says this is his first 4 stroke 150 and was very impressed by the way it pulled out of the hole even with the overpitched prop.I could not be happier with this repower so far!
The boat will be better out of the hole with the over pitched prop, its going to have a worse hole shot but a higher top end if you decrease the pitch.
Quote from: "slippery73"The boat will be better out of the hole with the over pitched prop, its going to have a worse hole shot but a higher top end if you decrease the pitch.I believe you have that backwards. A decrease in pitch will give you a better hole shot and lower top end.
