Thanks for the advise, I will get some pics soon, and see about posting them... probably not in the water as I have just gotten all the salt off and covered her a while, don't want to do that again soon.I appreiciate every who has read and responded so far, but please keep the info coming..As for changing the prop I don't disagree at all, a new prop is in the future, but deciding the best stab at size and pitch will come after I feel the motor high is been addressed to the best of my knowldge/or financial resouces. The current prop is a 15 1/4 X 19 SS (guessing Stock prop). M19 if I recall correctly.Also forgot to metion, I did raise the motor up one hole allready. I have another hole I could go up, but the bracket has 4 drilled holes on the top, and a long slot adjustement on the bottom. The existing bolt on the bottom slot is very close to maxed out, so can not raise the engine enough to keep that slot bolt in place and use the last hole on the bracket. This is real hard without Pics... sorry.Marc, the other marc, not to offend the Original, FP225
Aswaff, appreciate the picture, but honestly, i don't see any plate anywhere, i'll take your word, but I cant see anything above the spray.
I will be going through this exercise in he spring, My Yamaha 250 HPDI is sitting up 1 1/2 on the transom and I want to make sure it is correct.I wouldn't mind a lower top end speed (never get to open up anyways) if I got a quicker plane without using tabs
