Author Topic: 1/4" diameter holes thru 1/4" thick fiberglass- fill  (Read 667 times)
November 13, 2011, 06:26:56 PM
Read 667 times
HIFLUTIN
« on: November 13, 2011, 06:26:56 PM »
Have a bunch of approx 1/4" diameter holes thru 1/4" thick fiberglass on a "verticle" surface that I need to fill before Gel-Coat, looking any easy suggest.I know Water resistant filler will "fill" but  fraid it might "pop-out" down the road, Iam no "glass expert" but can get by
November 13, 2011, 07:17:34 PM
Re: 1/4" diameter holes thru 1/4" thick fiberglass- fill
« Reply #1 on: November 13, 2011, 07:17:34 PM »
I'd go with either Bondo-glass (basically Duraglass) or MarineTex.  Tape off the back sides of the holes, fill, DA flush, fill in any air voids, DA flush again, re-gel, DA and buff...
Bondo-glass is $12 a quart at Wally World.  We used Duraglass at WC/AS, same stuff...
November 13, 2011, 07:23:38 PM
« Reply #2 on: November 13, 2011, 07:23:38 PM »
What Seabob suggests is perfect but I would go one step further and hit the holes just a tad with a countersink bit.  The chamfered edges will help prevent cracking and help prevent your filler from popping out.
November 13, 2011, 07:31:31 PM
« Reply #3 on: November 13, 2011, 07:31:31 PM »
Wing, you are correct.  And, to go one step further, when installing hardware and equipment in smooth gel, c/sink your screw holes.  Gel won't chip out when you drive the screw in...
November 14, 2011, 08:20:00 AM
Fletch170
« Reply #4 on: November 14, 2011, 08:20:00 AM »
SeaBob,
I am waising my scuppers, is this the best way to fill the holes? Or should I glass the backs?
-Fletch
1981 2100 CC Hydra Sport
1976 170 (sold)
November 14, 2011, 01:50:19 PM
« Reply #5 on: November 14, 2011, 01:50:19 PM »
Quote from: "Fletch170"
SeaBob,
-Fletch
Fletch,
Considering the size and location of the scupper drain holes, I'd use 2 layers of 24 oz. on the back sides, then as described above.  I really like the Bondo-glass as it has short strand glass in it...
November 14, 2011, 02:21:27 PM
Fletch170
« Reply #6 on: November 14, 2011, 02:21:27 PM »
Roger that Bob.
Thank you for your help.
1976 170 (sold)
