Author Topic: 97. 215 DC Tachometer rebuilding or replacement  (Read 61 times)
April 26, 2021, 07:47:54 AM
Read 61 times
Ben DiGregorio
« on: April 26, 2021, 07:47:54 AM »
Anybody have a source for rebuilding or replacement
April 26, 2021, 08:23:36 AM
Re: 97. 215 DC Tachometer rebuilding or replacement
« Reply #1 on: April 26, 2021, 08:23:36 AM »
Need just a little more info.
Is this a Yamaha multi gauge tach?
If so, has the LCD screen turned the dreaded "orange"?
April 29, 2021, 07:39:46 AM
Ben DiGregorio
« Reply #2 on: April 29, 2021, 07:39:46 AM »
It’s a Yamaha 250
April 29, 2021, 11:00:41 AM
« Reply #3 on: April 29, 2021, 11:00:41 AM »
It’s a Yamaha 250
OK, I'll go out on a limb here and guess you have a Yamaha 250hp motor and go a little more and guess it uses Yamaha's multi gauge for instrumentation and the gauge face is no longer readable and looks like this. :ScrChin:
If all of this is correct, Jason (aka boatnamesue) might be able to help with where to get the "polarizer" screen replaced.
Here's another option where the screen is replaced.
https://www.ebay.com/itm/174506128322?_trkparms=ispr%3D1&amdata=enc%3AAQAFAAACUBaobrjLl8XobRIiIML1V4Imu%252Fn%252BzU5L90Z278x5ickkKQ3D59%252FksmrAqH9M4NgB33srWvbohoeEkEhJlRvobd%252Fw9G0G3l%252Fg5Et8%252FRVsY8DJtreuSt9eoFbfb6%252FuwdADQSm1WwMB3QjNTELUBSz8DXjIKggpuHmB%252BvYDHgUZVab0MbrtlgGIacNVm6wiz6Bu%252Bgcdvh7qt5bPr9I2chL85OBdZWAWzBJgLls%252BwI86eFXRVqRm%252FXVD8mQBCmUkT2i5TIP8OeckhdEb3XpOerZcfYc6C7YYplWFlNV8SYjQ8ziBiyBbAk%252Bx042ZDEWRCsg01VpjHgmaa%252FWyJHYlWewHo%252BzEvb%252FbdSsmEWMhvzTShRNHgntzco8PNjV9DIp4%252FZZ%252B%252BOTg%252Bx%252F6CqYQPMUMLzJpS8LA1hSCzXPjBy3ZkwwnEqV14XKLQ8a2IdM8XnTZZeLgK4pB1Y9QLXLYzhY%252FqZgKdqzT8%252BlV9tmAkQd2y3WuUK4nDujxEHUXRo85fpJ6dKwrHLRDB%252BkmTPqNNy%252BMltJ%252BwM%252FJTFV4HyUB4iQwVgVKO2EIKBWzmJBPA07lJ9hasfWWR387rDO1hV6PyRcy3sZ%252BDY%252BFiFezNQyuBgYWkIzquGB5oZam9Jo%252BS2CMiPChS7mhIHLCCzHgDuD4V9%252FZwJr4fiQE6ndn83K6tj3Nmujf8hyL2CIoHoW8oWhjzLDOht6BUxYBlVTT%252BFV9cNRSWfJwv1fjzpqOW%252FIoqMjYWwYdfCyss%252BH9NJP4r3LrISXZ%252F738Zxwmug63iEfjH95mIqpj2Q8%253D%7Ccksum%3A174506128322d1cb38e71a1d4f48b4e63f0cbce612e4%7Campid%3APL_CLK%7Cclp%3A3268220&chn=ps&norover=1&mkevt=1&mkrid=711-117182-37290-0&mkcid=2&itemid=174506128322&targetid=1192081307264&device=c&mktype=pla&googleloc=9011577&poi=&campaignid=12873834712&mkgroupid=120270033494&rlsatarget=pla-1192081307264&abcId=9300536&merchantid=6296724&gclid=EAIaIQobChMIo8uT-Nqj8AIV0vDjBx3BYA2wEAQYBCABEgJWU_D_BwE
 If not, Yamaha updated the multi gauge line in 94 and I have seen your style (97) for sale online.
I did not take the time to look up the model gauge relative to your motor for a cross reference but you get the idea.
https://www.partsvu.com/yamaha-digital-multifunction-tachometer-6y5-8350t-d0-00-supersedes-6y5-8350t-83-00.html?utm_source=google_shopping&utm_medium=cpc&adpos=&scid=scplp6Y5-8350T-D0-00&sc_intid=6Y5-8350T-D0-00&gclid=EAIaIQobChMIo8uT-Nqj8AIV0vDjBx3BYA2wEAQYAiABEgJHoPD_BwE
Good luck. :thumright:
April 29, 2021, 08:27:23 PM
boatnamesue
  • Jason
« Reply #4 on: April 29, 2021, 08:27:23 PM »
https://gaugesaver.com
Restoration or replacement depends on what's causing the issue.....If LCD issue then it's toast.  If polarizer issue then its restorable.  Pulled from the above noted website....
"Many older Gauges have LCD Leaks. The symptom of this is a dark black ‘INKY’ spot at the bottom of the LCD Screen (sometimes accompanied with missing segments on the screen when powered up). Restoration will not fix this.  Polarization Film replacement can resolve faded LCD problems on many gauges or instruments.  If the LCD can be removed and reinstalled without destroying the integrity of the case, there is a good chance that the repair will bring back the clarity.  If you’re not sure, send a picture over, or send the device to me. Again, IF WE CAN’T FIX IT, THERE’S NO CHARGE!"
Jason
1976 AS 170
1998 S115TLRW
April 29, 2021, 08:42:13 PM
« Reply #5 on: April 29, 2021, 08:42:13 PM »
Thanks Jason.
May 03, 2021, 10:40:52 AM
Ben DiGregorio
« Reply #6 on: May 03, 2021, 10:40:52 AM »
Thank you. That is most helpful.  Can the same be done with the speedometer
Ben
May 03, 2021, 08:57:46 PM
boatnamesue
  • Jason
« Reply #7 on: May 03, 2021, 08:57:46 PM »
Yes.  Here is the before/after for my tach which had a bad polarizer....
Jason
1976 AS 170
1998 S115TLRW
May 06, 2021, 04:31:02 AM
Ben DiGregorio
« Reply #8 on: May 06, 2021, 04:31:02 AM »
Thank you all for the information.
Ben
