'Cept give you a good buzz. Was wiring an Osprey console one winter when the putty was still kicking off (out-gassing). Ended up across the street in sub-assy, my buddy who ran S/A asked what I needed. Had no clue...
Bob,That happened to me in college, but I would end up at 7 Eleven eating doritos, beef jerkey, and combos having no idea how I got there.
Fletch,If you are only painting small parts, I would make a cheap hot box for curing out of the foam Dow Blueboards that you can get at Home Depot. Just duct tape together a 5 sided box of blueboard (no floor) and cover the parts when you get done painting. Use an electric blanket with plastic sheeting as the floor of your box and cover the parts with your blueboard box to cure. There are race boat builders who use this hot box concept to post cure their pre preg epoxy layups. Their hotboxes are obviously much bigger and require overhead gantries to drop down over the hull molds, but the concept is the same. Instead of radiant heat coils on the floor, you can use an electric blanket. Instead of steel to hold the panels together you can get by with duct tape.Incidentally, when you spray in cold weather, it often helps to spray a thin tack coat on the parts to begin. Runs are more prevalent on edges and corners of small parts in cold weather, so I've found that a thin tack coat helps minimize potential runs. Minimally, you should turn down the volume relative to warmer temps.
