Replacing shift and throttle cables 170/Yamaha 704
Topic: Replacing shift and throttle cables 170/Yamaha 704 (Read 720 times)
February 12, 2019, 08:29:33 PM
Read 720 times
alandry100
February 12, 2019, 08:29:33 PM »
Noticed at the end of the season that the control cables are cracking so time to replace.
I have a 2005 Yamaha 2 stroke with 704 controls. Wondering what cables to get? Are all Yamaha cables the same (other than length)? I have been looking but the parts diagram for the engine that I have - does not specify part number for the cable?
Any insight would be appreciated.
A
79\' 170
2005 Yamaha 70 two stroke
February 12, 2019, 10:00:08 PM
Re: Replacing shift and throttle cables 170/Yamaha 704
February 12, 2019, 10:00:08 PM »
You may find the numbers you seek on the ends of the cables attached at the 704 control end.
February 13, 2019, 12:44:26 AM
boatnamesue
Jason
February 13, 2019, 12:44:26 AM »
Know your hp and model, then go here:
https://www.boats.net/catalog/yamaha/outboard-by-year/2005
If you still can't locate the parts, sign up as a member here:
http://www.yamahaoutboardparts.com
When you post the question provide your year and model. That's the best yam outboard forum bar none.
Jason
1976 AS 170
1998 S115TLRW
February 13, 2019, 03:26:50 PM
alandry100
February 13, 2019, 03:26:50 PM »
You are wise Seabob. They are morse cables D32377-003-156.1 It looks like they are no longer available - the Teleflex replacement appears to be TEL-CCX633-13. Should I go with that or the Yamaha? - Which I don't know - part number is not included in the parts diagram. Must be on the controls diagram.
79\' 170
February 13, 2019, 04:30:48 PM
February 13, 2019, 04:30:48 PM »
I spoke with my Yamaha dealer here in Tally and he recommended the Teleflex cable over the Yamaha. I just quickly glanced at the Teleflex site and it appears you have the correct part number for the replacements. That old Morse # equates to a 13' length so...
If you want a warmer, fuzzier feel, you could try speaking with Teleflex tech department. They have been helpful in the past and could confirm you have the correct parts.
February 21, 2019, 08:29:20 AM
alandry100
February 21, 2019, 08:29:20 AM »
Ok - got the cables - started the install - so far so good the rigging channel on the 170 makes this kind of work not too bad.
Two things - any clues on how to make sure they are close to adjusted on first try? I have counted the number of turns for each of the nuts.
Also - since I have it off I want to replace the aging plywood housing and will need to remove the tilt trim wiring - the first one seems easy.
The second one seems a little more difficult.
Any thoughts on its removal?
79\' 170
February 22, 2019, 12:37:59 PM
alandry100
February 22, 2019, 12:37:59 PM »
All done - let's hope it works alright. Looks right - when shifted into forward or reverse, throttle does not move. Only after in gear does that engage.
79\' 170
