Aquasport Discussion
Cooler Seat mounting on 225 Explorer?
Topic: Cooler Seat mounting on 225 Explorer? (Read 377 times)
February 02, 2021, 07:44:25 PM
Read 377 times
Beaver State Rich
February 02, 2021, 07:44:25 PM »
Howdy folks! Finally getting around to making some modifications to my (new to me) 2002 225 Explorer. We got a great deal on a cooler seat that I want to mount for extra seating. It appears the manufacturer recommends using #10 SS screws. However, this seems really weak for something that would have so much stress on it. Or, is this "OK" for the application? Other option is a SS toggle but that's a lot of 1/2" holes to put into the deck. Any other suggestions or work arounds would be welcome! I can fabricate a bit so an out of the box solution is OK.
Tight lines.
February 02, 2021, 07:47:59 PM
Re: Cooler Seat mounting on 225 Explorer?
February 02, 2021, 07:47:59 PM »
Use Wellnuts instead of tapping screws, look it up...
February 04, 2021, 08:08:54 AM
CTsalt12
February 04, 2021, 08:08:54 AM »
Just make sure you don’t screw all the way through the deck. Fitz’a option seems great. Or you could use the widest screws the mount will allow-would not use toggle bolts. 5200 works well for this application. I mounted my leaning post with it last spring and unfortunately needed to remove it this year. Tough for sure, but it can be removed contrary to what some say.
There is also the option of over drilling and filling with epoxy, then drilling a smaller hole within the epoxy ‘plug’ you’ve created.
Jimbo
1989 175 Osprey
April 12, 2021, 10:53:21 PM
wesman68
April 12, 2021, 10:53:21 PM »
You could tap threads in the epoxy also and use machine screws. Just do not overtighten.
April 14, 2021, 04:39:52 AM
dakota
908 410 0742
April 14, 2021, 04:39:52 AM »
just my thoughts, had installed a cooler seat& cushion on a boston whaler. put st.st.marine "loop" on a small(1"x3"x1") piece of teak attached w/#8 st.st. screws(2) to floor, then used large heavy duty rubber bungee to cooler handle on each side. never moved w/someone sitting on cooler underway! could remove cooler easy.can go w/o teak piece & leave a loop only in floor. thats what I plan to do on my 222 Asport when floor is done. cooler is 40"lg.x 20"w.... worked for us! dakota
dakota
April 16, 2021, 10:24:56 AM
CTsalt12
April 16, 2021, 10:24:56 AM »
Quote from: fitz73222 on February 02, 2021, 07:47:59 PM
Wow, I’m going to I start using wellnuts on any deck areas where I have access to both sides ! Good call.
Jimbo
1989 175 Osprey
