Author Topic: Clamshell thru hull  (Read 2343 times)
March 05, 2012, 04:27:55 PM
305kingfisher1954
Re: Clamshell thru hull
« Reply #15 on: March 05, 2012, 04:27:55 PM »
Well, I think I got my answer..thanks guys..as for turning the pump on or off, I think I'll take my chances and leave it on, knowing myself, I'm sure there will be times that I'll forget to turn it back on when I arrive at my destination,,,I am installing the Hammerhead 43 galllon livewell and thinking about going with a rule professional 800 gph, shurflo bait sentry or pirahana 800 gph pump with a johnson 5.3 gal washdown pump connected to the port in the livewell pump...Anyt recomendations for the best livewell pumps to use ????
March 05, 2012, 04:38:59 PM
« Reply #16 on: March 05, 2012, 04:38:59 PM »
Matt and the other guides will hopefully input on the 800 of their liking.
The good news about your setup with the diaphragm pump above-line...you will never worry about losing prime on the bait pump.
March 05, 2012, 06:09:07 PM
Keith Knecht
« Reply #17 on: March 05, 2012, 06:09:07 PM »
Ok here's one to add to the discussion.  I don't try to keep threadfins and green backs alive. Don't need a lot of circulation so I'm going to try something on this boat that I've always wanted to do.  The factory inlet is at the bottom of the baitwell and comes through the transom.  I am going to use a Rule through hull baitwell pump mounted very near the top of the water level that it seeks in the bait well. The pump will be mounted throught the skin of the bait well and pump water out of the bait well via a hose and thru hull fitting.  Will it work?
March 05, 2012, 06:53:52 PM
Capt Matt
« Reply #18 on: March 05, 2012, 06:53:52 PM »
I run 2 pirahana 800 gph pumps to my hammerhead livewell along with a johnson 5.3 gal washdown pump all on there own thru hull fittings. The pirahana pumps are cheap and easy to switch out, I have ran Shurflows and rule tournament series pumps in the past and in my opinion they do not last any longer than the cheap pumps. My clam shells point forward.
The livewell pumps do loose prime when I lift the boat out on the lift but once back in the the water they start shooting water as soon as I start moving forward. I run at least one of my livewell pumps all day everyday I'm out and usually get between 3-6 months life out of a pump, the stainers roughly double the life of the pirahana pumps.
Maybe I'm not understanding your pump idea.  I don't think will work as its too far for the pump to pull the water. I have seen these hammerhead livewells rigged with a recirculating pump mounted through the skin of the well, its a great option to have besides your raw water pumps if you are towing your boat or fishing during red tide.
Capt Matt
Light tackle sportfishing
March 05, 2012, 07:30:03 PM
wessnapp
« Reply #19 on: March 05, 2012, 07:30:03 PM »
Quote from: "Keith Knecht"
You could always call Robin and ask  :lol:
I think the distance of pull for the pump will be your greatest obstacle.
I am still soooooooo unbelievably angry that the recirculating pump was not installed in my livewell.
St. Petersburg, Florida
March 05, 2012, 07:41:54 PM
« Reply #20 on: March 05, 2012, 07:41:54 PM »
Keith, see what you're getting at.
You are thinking push vs. pull in a closed system. In theory it should work, but as wess says, it is a long run. There probably won't be enough pressure on the discharge end to allow for pull on the intake.
The main thing is to get water to the well (via a pump) and an outlet 2X diameter of the inlet via gravity will remove it. If you want a low flow...use a valve or go to a 300 gph.
March 05, 2012, 07:45:54 PM
« Reply #21 on: March 05, 2012, 07:45:54 PM »
Quote from: "Capt. Bob"
Quote from: "wessnapp"
Wow - that got heated.  I almost thought I was on the THT for a minute.
Nah,
Just good ol' boys talking about hogwashin'  :mrgreen:
No offense meant and none taken.  The scoop is meant to point forward, hence the term high speed pick-up.  CB your point is a valid one, less use - longer life, but not relevant to the opposite sides of the fence that Scott and Wesnapp find themselves; Scotty, Wesnapp, and myself are using the livewell.  My point was that leaving the pump on at speed does not hurt the pump and that the believe that turning the pump off when the boat is at speed is better for the pump is, wait for it............"Hogwash". :mrgreen:
At speed, regardless if the pump is on or off the impellor is spinning and the pump is accumulating revolutions.    The biggest cause of pump failure is debris; weeds, sand, shell.  If you want to get the most out of your pump be sure and install a strainer.
305King - I run an 1100 rule on my 48 gallon livewell.  Its stays on from the time bait is caught till the boat is back on the trailer.
March 05, 2012, 08:27:50 PM
« Reply #22 on: March 05, 2012, 08:27:50 PM »
Quote from: "Blue Agave"
Nah,
That is true, I saw it.  That's what Fernando does, the well is being constantly regenerated with new water as the well drains via the overflow.
Yes, the scoop faces forward.  And it will fill a well when up to speed, with the shut-off valve open.  But does it hurt the pump to have it off...or on?  I suppose everyone has a different take on it.  I would say no, the pump is not harmed by the water passing through it when off.  But how would I know? A simulation test would have to be set up to determine that.  Force water through a pump to simulate planning speeds versus turn the pump on and duplicate the same speeds, see which one lasts longer.  Lots of fun...
So what would I do?  Turn the pump on when the boat hits the water, leave it running until I get my bait.  Turn it off, then run it every half hour or so, to get some clean water in there.  Oh, dammit, there I go again, one would have to be cognizant as to when the pump scheduled run time is...might just throw the Frabill overboard, that solves the problem...a 40 gallon Frabill!!!
March 05, 2012, 08:48:28 PM
« Reply #23 on: March 05, 2012, 08:48:28 PM »
Bob sound like you would need a timer http://www.cabelas.com/livewells-aerato ... adType=pla
March 05, 2012, 09:04:45 PM
« Reply #24 on: March 05, 2012, 09:04:45 PM »
Quote from: "Circle Hooked"
I need a timer for my life!!!
March 05, 2012, 11:59:36 PM
« Reply #25 on: March 05, 2012, 11:59:36 PM »
Naw man...you're only thirty years old :lol:
My thinking is...if you're live bait fishing that day...get on the boat, shove some water through the clamshell....turn the damn thing on and leave it on. Your hard to catch live bait never died by leaving the pump on.
Take the opposite scenario, real world fishing adventure.
You fill the livewell with the pump on..and go to catch bait. You catch bait...turn the pump off...plane up. You're riding along, happy.
You slow down to cross a freighter wake. Or a yacht wake. Or whatever, you catch air. Remember, the pump is off.
You are only off-plane a few seconds. But not known to you...you've sucked air, lost flow. Airlock. Maybe the problem is in the pump that was turned off and now refuses to flow freely.
So you get to your secret hole 35 minutes later. You open the livewell....a couple out of fifty are sorta alive. The rest...dead. NO water in the livewell...empty. The water has drained back out through the livewell 3/4 inlet at the bottom of your tank, straight out the clamshell pickup in the bottom of the hull near the transom.
Water ALWAYS reaches the lowest point.
Happens a bunch. But really sucks when money is on the line in a KMT.
March 06, 2012, 05:33:34 AM
wessnapp
« Reply #26 on: March 06, 2012, 05:33:34 AM »
Good point - it's on all day now.
