While rigging mine I had everything ran except the wiring harness, when I took it to the marina to rig the motor they had to take everything out of one rigging tube to run the motor harness. The plug and play connections for the new mercury wiring harness are now huge and impossible to run with anything else in the rigging tube. Even with 2 rigging tubes with 45 degree sweeps it was a pain in the butt. Like Gran said leave a extra pull in there just in case you need to add anything laterI feel your painCapt Matt
Thanks alot guys! Fedex just dropped the steering cable off right now. I will let you know if the dawn, electrical tape, and bullet shaped ends will work or not by this afternoon!To extend my battery cables, would yall recommend buying new yamaha ones that are one single line, or could I go to lowe's & buy some heavy gauge wiring, then bolt it to the existing yamaha battery cables? Kind of like a battery cable extension cord?
If one is thinking about relocating the batteries to the helm, and thus having to run new, larger gauge cable, this tool is invaluable...Harbor Freight sells them, hydraulic, as you can see by the dies out of their slot, crimps up to 00GA, I've even crimped heavy wall 2/0GA fabbing a cut down die to get the lug in the jaws. You can't rent a heavy duty crimper anywhere (not Autozone or Advance Auto Parts), and to buy one from, say Grainger or an electrical supply house will run you north of $250. Got mine on sale for $45 a couple years ago, just saw it on sale again for $54. Still a steal, mine has paid for itself a 100 times over...
I just bought one of those crimpers at HF an hour ago and it was indeed $54.
That's good - was wondering how it would work. Now I have to find a #4 end that is 3/8" locally.
