Author Topic: Osprey 205 2001 Plumbing Issues  (Read 304 times)
July 27, 2022, 05:17:06 PM
Read 304 times
Cape Cod Mike
« on: July 27, 2022, 05:17:06 PM »
Hello All:
I am a new owner of this 2001 beauty. I had previously owned a 15 foot whaler that did not have a live well, washdown or bilge so its all new to me.  I had a mechanic doing some work on the engine and he gave it a once over and told me that the bilge pump sounds like it works but we were in my driveway so not a real test.  I have a few questions.
The Y valve is frozen and I don't want to force it - any suggestions? I would like to be able to use the wash down and to a lesser extent the livewell.  If I need to replace the valve, where can I get one and are they standard size? This problem may be related to my next one....
The other question is that the fish boxes do not drain at all.  I had to use a siphon to get them to empty which is not convenient.
Anyone who can give me a primer on how to use these and get them to empty?   I read a few posts here but they were talking about a different model so not sure it is the same design.
Much appreciate your advice.
Mike
July 27, 2022, 09:55:20 PM
Re: Osprey 205 2001 Plumbing Issues
« Reply #1 on: July 27, 2022, 09:55:20 PM »
Pick your poison.
https://www.defender.com/category.jsp?id=2234265&path=-1|51|2234261
July 28, 2022, 10:25:48 AM
plugger
« Reply #2 on: July 28, 2022, 10:25:48 AM »
I had a 2002 for a while now, the fish box’s drain via a massarator pump, it’s a lousy set up . After two pumps failed I started hand pumping . Later when I re powered I had the pump removed altogether and since I rarely use it as a kill box it drains into the bilge.
If your pump is working plug one box at the end to increase the draw on the other.
July 28, 2022, 02:26:53 PM
Cape Cod Mike
« Reply #3 on: July 28, 2022, 02:26:53 PM »
Pick your poison.
Thanks for your response and advice!
September 15, 2023, 04:58:20 PM
Scode68
« Reply #4 on: September 15, 2023, 04:58:20 PM »
Not sure which way you went but my 2001 215 sport has what looks to be a Bosworth Y valve.  It's frozen as well but it does have screws holding it together making me wonder if it can be taken apart for cleaning.
https://thebosworthco.com/products/productp.php?baseid=YV-094D-B
2001 Osprey 215 Sport
