There is a thread of my install.
http://classicaquasport.com/smf/index.php?topic=4460.msg28118#msg28118I believe this is wingtimes tank install.http://classicaquasport.com/smf/index.php?topic=4360.msg27422#msg27422This is his coffin lid recore.
To hold the tank in place I used the factory method of straps, but I insulated them from the tank with split vinyl hose. For the holes from the rigging trough, I just sealed mine up with rope caulk/putty.
Sorry, I meant I sealed up the hole at the end of my rigging trough on my 170. so you wouldn't see that in the topics about my 200XF. I was getting water in the bilge of my 170 and I could not find the source. Turns out it was the hole in the end of the rigging trough where the wires going to the fuel tank went thru.
The straps were simply screwed to the coffin sides before the tank was placed into the coffin. This is how the factory did it.
Quote from: wingtime on April 30, 2017, 10:48:16 PMThe straps were simply screwed to the coffin sides before the tank was placed into the coffin. This is how the factory did it.Really, huh. What were the screws anchored to? Stringer? Cause the coffin liner is fairly thin, or at least it looks that way.
First, if you are going the aluminum route, you can have the fabricator weld mounts on the tank. Mounting aside, your biggest task is sealing the hatch and the deck plate(s) you have. It is the biggest source of water intrusion you have to deal with in replacement of your tank. Silicon caulk isn't the trick here IMHO but rather a sealer/adhesive such as 3M's 4000UV. bedding the hatch and making sure the deck plate is as watertight as possible is the key. I replaced my pop out style plates with screw in and they seem to stay dry. Don't forget the fasteners. They too are a source of water intrusion (rain, wash down). Water runs from bow to stern under the coffin so that isn't a concern (assuming the coffin is sound). Mount the tank so air can get around the surface, keep it from sliding around and seal the access thoroughly and an aluminum tank will last a long time.Good luck.
