Osprey Models
Osprey 200 Inner hull finish
Topic: Osprey 200 Inner hull finish (Read 540 times)
September 19, 2019, 10:51:50 PM
Read 540 times
Jlcalzada
September 19, 2019, 10:51:50 PM »
Need some help. Cleaning up a 1998 Osprey 200, should the interior of the hull achieve a glossy finish like the exterior? It was chalky and got it very lean and smooth but not glossy.
September 20, 2019, 07:06:45 AM
Re: Osprey 200 Inner hull finish
September 20, 2019, 07:06:45 AM »
Sounds like typical old gelcoat. Might need to compound it to get it shiny.
September 20, 2019, 07:23:23 AM
September 20, 2019, 07:23:23 AM »
Try this:
https://www.prestaproducts.com/Ultra_Cutting_Creme-details.aspx
And for additional gloss, finish with this:
https://www.prestaproducts.com/Ultra_Polish__Chroma_1500-details.aspx
Then apply your favorite wax. I've found that the Cutting Creme works great by itself on all but the heaviest oxidation. For that use this:
https://www.prestaproducts.com/Gel_Coat_Compound-details.aspx
This is an older photo but taken shortly after buffing with the Cutting Creme.
That's 28 year old gel coat.
PS....Once you got her all shiney, clean up the blood and guts with this stuff. Works very well.
https://www.prestaproducts.com/Marine_Hull___Deck_Cleaner-details.aspx
September 20, 2019, 05:49:01 PM
Jlcalzada
September 20, 2019, 05:49:01 PM »
Thank you gentlemen. I'll try the cutting cream and polish on a small Area first. If we don't achieve the desired results we'll resort to the cutting compound.
Osprey Models
