Author Topic: Transom mount transducer -but want thru hull  (Read 973 times)
March 14, 2012, 09:15:39 PM
Read 973 times
HIFLUTIN
« on: March 14, 2012, 09:15:39 PM »
Gettin ready to put a mid range fish finder on my 170
Garmin or Lowrance.
Most all come with Transom mount transducers
I prefer a thru hull (keep the boat in the water for an extended period of time)
What are my options?
Can I epoxy a transom mount for a thru hull?
Or will the factory exchange/trade in ?
March 14, 2012, 09:30:43 PM
Re: Transom mount transducer -but want thru hull
« Reply #1 on: March 14, 2012, 09:30:43 PM »
Quote from: "HIFLUTIN"
Garmin or Lowrance.
Yes, Airmar even gives instructions on how to mount a transom mount in the hull as a shoot-thru...
March 14, 2012, 10:30:32 PM
« Reply #2 on: March 14, 2012, 10:30:32 PM »
You lose temp in shoot-thru, but it's pretty easy to install.  Be careful about location - you need a flat area on the hull that stays wetted or you need to get an angled transducer.  Don't use 5200 - use epoxy to get a good bond to the hull.  Try out your location first with clay and water or gel.  Once you've got a good spot, clean it, sand it, and epoxy that thang down!
March 15, 2012, 09:50:37 AM
CTsalt12
« Reply #3 on: March 15, 2012, 09:50:37 AM »
Why not just mount on the transom?  I keep my boat in the water all season as well. As long as you throw on some bottom paint (but avoid temp sensor), and seal the screw holes properly, I don't see any detriment to mounting it here.
Jimbo
1989 175 Osprey
March 15, 2012, 04:33:25 PM
HIFLUTIN
« Reply #4 on: March 15, 2012, 04:33:25 PM »
Quote from: "CTsalt12"
Iam a low maint type
Have delt with transducers before & even with bottom paint etc. them little critters can find ever nook & cranny to get in making a pain in the _ss to clean.
March 15, 2012, 10:40:08 PM
« Reply #5 on: March 15, 2012, 10:40:08 PM »
Where I fish a transom mount will get knocked off sooner or later.  I have never had a transom mount that would work at all speeds and attitudes.  My shoot-thru always works.  It's a common Airmar P-66 transom mount sitting in a little well full of water in the bilge.  (It never runs out of water because my livewell plumbing leaks a little and keeps it wet.   :wink: )
As far as temperature readings they may not change quite as fast but they still run pretty close to an external temp sensor but I probably only have about a half-pint of water around the xducer.  it only needs enough water to chase the air out from between the xducer and the hull.
March 16, 2012, 05:36:08 AM
Capt Matt
« Reply #6 on: March 16, 2012, 05:36:08 AM »
Nothing worse than spray or grass hung on a transom mount transducer and if you operate your boat in skinny water you will end up breaking it off sooner or later. Garmin makes a thru hull that sits in a oil filled mount inside the hull, even in reverse it rarely loses the bottom signal. As far as water temperature goes a regular transom mount mounted inside the hull will give you hull temperature. I have a lazer pointer I use for surface temperature.
Capt Matt
Light tackle sportfishing
