Author Topic: Installing new rub-rail insert -- How big a job?  (Read 1027 times)
August 07, 2010, 09:02:59 PM
Read 1027 times
Glock Diver
« on: August 07, 2010, 09:02:59 PM »
Next project on my list for my 225 Osprey is replacing the rub rail insert.  Just curious if any of you fellas have tackled this chore.  I think new rubber is all it needs.
How long does it take, how much does it cost, and how big a P.I.T.A. is it?   :scratch:  Do I need a special tool?
Thanks!
Mike
August 07, 2010, 09:15:26 PM
Re: Installing new rub-rail insert -- How big a job?
« Reply #1 on: August 07, 2010, 09:15:26 PM »
Mike,
We made these out of 3/4" starboard, about 4" wide and 15" long.  Heated the insert with a propane torch used for shrink wrap, then lubed with WD-40...
It takes a technique, but once you learn it, you can install your insert in 30 seconds...no chit!
Get it hot in a 200 degree oven, keep a heat gun handy, a couple of slotted screwdrivers, take your time, and she'll go in... :thumright:  :thumright:
August 08, 2010, 12:21:55 AM
Glock Diver
« Reply #2 on: August 08, 2010, 12:21:55 AM »
I'm guessing I won't match your 30 seconds Bob!
But if I heat up the rubber in the oven, and use a heat gun while working... I don't need that nifty tool you crafted, correct?
August 08, 2010, 06:16:29 AM
« Reply #3 on: August 08, 2010, 06:16:29 AM »
I know when I installed my new rub rail I needed to put real rope inside it and it almost killed me.  I took a piece of 3/4" conduit and cut it at a 45, then slid the rope through it and stuck the conduit into the groove on the rub rail.  I used soap and a rubber mallet to work the conduit all the way around the boat - man was that tough.  I had a guy helping me and we took turns beating on the conduit to force it around the boat.  That was with real rope though.
August 08, 2010, 10:00:30 AM
Glock Diver
« Reply #4 on: August 08, 2010, 10:00:30 AM »
Found this video on Youtube.  Seems SOOO easy....
But hey, at least the narrator is pretty cute.  :flower:
http://www.youtube.com/watch?v=OG_mrSy5xKU
I think this insert they used is the round, tubular type, which unfortunately isn't the type my boat uses.
