Author Topic: shore power setup, 225ex ??  (Read 1135 times)
April 01, 2010, 10:09:26 PM
Read 1135 times
fishingdave
« on: April 01, 2010, 10:09:26 PM »
I got all my components for my shore power , just wonder if some can post pics of where the installed the inlet, panels , outlets etc.. also  did anyone bond all there thruhull fitings? what did you use to bond them?
2005 aquasport 225 explorer
2005 Yamaha 200F
April 16, 2010, 07:56:17 PM
fishingdave
Re: shore power setup, 225ex ??
« Reply #1 on: April 16, 2010, 07:56:17 PM »
anyone?
2005 Yamaha 200F
April 16, 2010, 09:00:40 PM
« Reply #2 on: April 16, 2010, 09:00:40 PM »
Dave,
When I was there, we never installed shorepower on a 225 or 245/250.  Do you want to know my opinion on how to do it?  Easy, but I can just run you through the component install, I can't provide you pics... :thumleft:
April 16, 2010, 09:41:17 PM
« Reply #3 on: April 16, 2010, 09:41:17 PM »
Bob i would be interested in how to set that up,thanks.
April 16, 2010, 10:14:01 PM
« Reply #4 on: April 16, 2010, 10:14:01 PM »
Quote from: "Circle Hooked"
Gentlemen,
I shall have a drawing tomorrow, based on MY opinions on how I would do it...hull inlet on the port side above the sink, keeps the AC runs short in the cabin should you want to place a micro on top of the sink.  Remove the b/head behind the sink and the companionway door sill to run a feed to the starboard side to install a duplex outlet.  Locate the AC panel in the b/head behind the sink, as well as the galvanic isolator behind the b/head.  GFCI's at both outlets...but then you have to ground the 120AC ground to the 12VDC ground bus, which is on the starboard side...
Drawing tomorrow... :salut:
April 17, 2010, 07:26:34 PM
« Reply #5 on: April 17, 2010, 07:26:34 PM »
Alright guys, here's a schematic on how to install shorepower on your Explorers...
Remember, use GFCI outlets on both sides, and be sure to tie in the 120VAC ground to the 12VDC ground...
Feel free to parse, dissect, criticize, call me an idiot, or send me a beer! :cheers:
Bob C
BTW, if you want it in PDF form, let me know...
April 18, 2010, 08:49:43 PM
« Reply #6 on: April 18, 2010, 08:49:43 PM »
Thanks Bob.
July 04, 2010, 12:22:53 PM
fishingdave
« Reply #7 on: July 04, 2010, 12:22:53 PM »
where would you mount the power inlet? on portside front or on the rear?
2005 Yamaha 200F
July 04, 2010, 02:21:31 PM
« Reply #8 on: July 04, 2010, 02:21:31 PM »
Quote from: "fishingdave"
Dave,
Aft, just forward of where the seat base ends, and about 10" up from the walkaround...
July 04, 2010, 09:05:15 PM
fishingdave
« Reply #9 on: July 04, 2010, 09:05:15 PM »
so pretty much where the railing starts, kind of mid ship?
2005 Yamaha 200F
July 04, 2010, 09:16:45 PM
« Reply #10 on: July 04, 2010, 09:16:45 PM »
Kinda like midship...
