Author Topic: 1987 222 cc  (Read 521 times)
March 29, 2020, 02:55:55 PM
Read 521 times
jep489
1987 222 cc
« on: March 29, 2020, 02:55:55 PM »
Hello, new to the forum; I just bought a 1987 222 cc with ttop with full helm up top.I been looking for this boat for a long time. I have 3 concerns with the boat:
1) The floor has a slight bounce in the floor along the starboard side of the console;does that mean the stringer is bad?
2) Was there wood used in the construction of this hull?
3) It came on a single axle trailer: most others I see online are double axle. Is the boat too heavy for a single axle trailer?
Any info would be greatly appreciated!
March 29, 2020, 06:41:40 PM
Re: 1987 222 cc
« Reply #1 on: March 29, 2020, 06:41:40 PM »
Is this an Osprey or a CCP?
No.
The deck (floor) may be compromised due to a failure of the mounting fasteners sealing to the deck. You stated it has a T-Top. Water entering the mounts on that side may have caused rot in that area of the deck.
No, not the hull itself but yes in the deck, transom, under gunnels and console.
Well it's on a single axle trailer but.. that's the exception to the rule. I would want it on a double axle myself. Save the single for a 170 Osprey.
March 29, 2020, 10:09:31 PM
jep489
Re: 1987 222 cc
« Reply #2 on: March 29, 2020, 10:09:31 PM »
That makes sense. It is the osprey. Thank you for your help!
April 07, 2020, 02:33:47 PM
jep489
Re: 1987 222 cc
« Reply #3 on: April 07, 2020, 02:33:47 PM »
I believe my 1987 222 osprey has the original fuel tank. The gauge isnt working but i filled it up for the first time last weekend and it took 76 gallons and I dont believe it was bone dry to start. I see the original specs show a 70 gallon tank; do you know otherwise?
thank you for your time
 PS dose a 80lb trolling motor do anything on the 222?
April 07, 2020, 03:51:06 PM
Re: 1987 222 cc
« Reply #4 on: April 07, 2020, 03:51:06 PM »
I believe my 1987 222 osprey has the original fuel tank. I see the original specs show a 70 gallon tank; do you know otherwise?
That's what the 86-87 catalog shows so no, I don't know otherwise. Tank may have been changed at some point. Only way to tell is to open the hatch and look.
