Author Topic: AquaSport 25 1980s vs AquaSport 271 1980s Center consoles  (Read 897 times)
November 09, 2019, 02:56:24 PM
Read 897 times
DMaN333X
« on: November 09, 2019, 02:56:24 PM »
I need help deciding between a 1980s Aquasport 271 and a 1980s aquasport 25. I heard that the 25 Aquasports can go in like 8 inches of water or something crazy aswell as far offshore, but how shallow can the 271's go? Also are they both as durable and as amazing as I hear? Could somebody please explain why one is better than another and why? Like how shallow they can go because I heard they could go in a few inches of water, and things like that? If I'm buying a boat I want to be sure. Also yes I will be redoing it, and I want to redo it like a modern boat, something similar to the Grady White Canyon 271 or the 25 depending on the boat I choose. Could somebody who knows about this stuff lmk what to expect in cost for a rebuild, for a modern look, but good durability. Thank you and have a great day.
November 10, 2019, 08:26:47 AM
Re: AquaSport 25 1980s vs AquaSport 271 1980s Center consoles
« Reply #1 on: November 10, 2019, 08:26:47 AM »
 Not sure what you're hearing where but:
There's a 25 CCP specs.
Draft is a claimed 12". I know that my 222CCP floated in a foot of water but 8" no. Maybe without an engine on back. :ScrChin:
There is the rare 281 Osprey which I believe started out as a 271 and gained a foot via decal. I can't recall seeing specs here but we have an original owner of this model and charter member of the Forum. He may chime in but again, float in 8", I'm not sure.
Lastly, while rebuilds remove weight gained over the years getting the hull back its manufactured "claimed" tonnage, most re-builders reinforce various sections of the hull resulting in a somewhat higher "dry weight" which would result in a deeper draft.
November 10, 2019, 04:34:40 PM
« Reply #2 on: November 10, 2019, 04:34:40 PM »
The 12 degree hulls draft 7-9" but the CCP and the newer Osprey have deeper V so the draft is more.
Capt.Bob covered the Osprey 271/281.
November 11, 2019, 08:16:48 AM
Keith Knecht
    • http://MinnowsandMonsters.com
« Reply #3 on: November 11, 2019, 08:16:48 AM »
I'm the guy that owned two 281s or rather one 271 and one 281 Ospreys.  Both the same boat.  There is absolutely no comparison between a 271 and a 25 CCP. The 271 has a 9'7 1/2" beam and a dry hull weight of 4700 pounds.  Two 125 gallon fuel tanks add about another ton when full.  Two motors another half ton.  I have owned a 250 Osprey and my son had Bob's 222 CCP, and while both were great riding boats, it's like comparing a Doberman to a Rottweiler.  The 281 is a beast.  The 271 will float in about 18" of water with the motors up and run in about 22" with the motors tilted up slightly.  It is a tank offshore and while the 25 CCP is also a great offshore boat, the 271 will take rough water a lot better.  The 25 might be a little drier if it's not too rough.  The 271 will not roll as much at anchor due to the large chines.  Just keep in mind that you will need a big truck to pull it out of the ramp and sometimes might be thankful for 4 wheel drive.  When backing down the ramp, don't be surprised if the truck slides backwards when you apply the breaks because boat motors, trailer, fuel, and accessories will most likely weigh a lot  more than your truck. It's a wet boat in rough water but is a great offshore boat that I fished in the bay as well and netted bait on the flats from it. Get ready for a healthy bill ( 2-5K) if you have to replace both tanks. No ready made tanks will fit.  Make sure it's on a triple axel trailer and torsions axles are best. The transoms go on all of these because the tube for the drain plug was not long enough for the thick transom and left exposed plywood that worked like a wick to soak up water.  Be sure the transom is good. Look for soft hatch covers on both tanks and around the console.  Hope that helps.  Just list any more questions that you might have and I'll try to answer them.
