Gallery
Gallery
22-2 Rebuilds
Mike's 77 22-2 Rebuild
Topic: Mike's 77 22-2 Rebuild (Read 29743 times)
July 23, 2018, 09:49:58 PM
Reply #30
Re: Mike's 77 22-2 Rebuild
Reply #30 on:
July 23, 2018, 09:49:58 PM »
I'm trying epoxy with a touch of silica and a handful of chopped glass strands mixed in since I had it on hand. Just poured it tonight so I will see how it turns out tomorrow. If that doesn't work out well I can get some 2 part mold plastic from the same company that got the silicone from. I'll post a picture with the finished result.
July 26, 2018, 08:15:38 PM
Reply #31
Reply #31 on:
July 26, 2018, 08:15:38 PM »
Here are the finished emblems. I made the first one with epoxy and it turned out ok but I over poured it and had to do a lot of trimming. Ended up pouring a few more out of poly so I can gelcoat them if I decide to later on. I'm pretty happy with them overall.
July 26, 2018, 10:37:29 PM
Reply #32
Reply #32 on:
July 26, 2018, 10:37:29 PM »
Looks good - make a few more and stash them because they break easily. I made a couple for my 170 and the bait bucket (I don't have a baitwell) banging up against it as we idled along, broke it.
July 27, 2018, 10:15:08 AM
Reply #33
Reply #33 on:
July 27, 2018, 10:15:08 AM »
Good idea. I'll cast up a few more while I have it all out still.
July 31, 2018, 09:57:49 PM
Reply #34
chris0614
Reply #34 on:
July 31, 2018, 09:57:49 PM »
Those came out great. I have seen replacements for sale once or twice before but it is much cooler to see this recreated using the original from your own boat.
July 31, 2018, 10:06:15 PM
Reply #35
Reply #35 on:
July 31, 2018, 10:06:15 PM »
Thanks Chris. I'm glad I was able to get a decent copy.
July 31, 2018, 10:24:48 PM
Reply #36
Reply #36 on:
July 31, 2018, 10:24:48 PM »
Got a little more done between the rain.
Mulch removed from the center stringer.
Refoamed with some leftover 4lb
And laid a strip of 1700 over the stringer tops, an extra layer over the tabs, and the chines.
I am also going to try the fence post trick to raise the stringer tops. Ripped two 5 inch posts in half for the sole and got 4 inch posts for the casting deck so it's got a little more of a step up.
August 01, 2018, 09:53:13 AM
Reply #37
Reply #37 on:
August 01, 2018, 09:53:13 AM »
Looks good!
August 01, 2018, 01:49:02 PM
Reply #38
Marcel4t
Reply #38 on:
August 01, 2018, 01:49:02 PM »
Looking great man, stringers are next for me. What is the fence post trick? Is them as forms to put glass on top off?
August 01, 2018, 01:54:02 PM
Reply #39
Reply #39 on:
August 01, 2018, 01:54:02 PM »
Thanks Marcel. Yeah, that's the idea. You glass them down to the stringer tops which raises the deck a little while giving you somewhere to run wires, etc without having to glass in a separate chase tube.
August 02, 2018, 09:33:30 PM
Reply #40
Reply #40 on:
August 02, 2018, 09:33:30 PM »
I ended up with a lot of bubbles in the center stringer. I've heard people say that glass doesn't like to go around bends very well and now I know what they mean. It seemed wrapped well when I left it but it pulled away in a few spots while it dried. I don't want any issues with water getting in there so I ended up cutting the top off again and filled all the voids up with resin. Lesson learned.
Also started to look at the transom tonight. Made a few exploratory cuts and pried back a few places. The sides have a good deal of rot but a lot of it is still pretty solid. I see a lot more grinding and chipping in my future...
August 03, 2018, 09:26:32 AM
Reply #41
Marcel4t
Reply #41 on:
August 03, 2018, 09:26:32 AM »
This is the bend of the fence post you're talking about? Maybe they needed to be roughed up really good?
August 03, 2018, 09:39:08 AM
Reply #42
Reply #42 on:
August 03, 2018, 09:39:08 AM »
No, it was the center stringer. I wasn't planning to add pvc there, I just wanted to keep the water out of it so I filled it with foam and wrapped a 6in piece of 1700 around it.
I am holding off on glassing the pvc down on the main stringers until I finish the transom so I can run it all the way back. In hindsight I should have done the transom first but it is nice to be able to climb in and out of the boat without a stepladder for now.
August 03, 2018, 10:46:56 AM
Reply #43
Reply #43 on:
August 03, 2018, 10:46:56 AM »
You may want to get some 12 oz biax tape. It’s available as cloth too. Conforms much better around outside radius.
August 03, 2018, 10:57:28 AM
Reply #44
Reply #44 on:
August 03, 2018, 10:57:28 AM »
Thanks, I'll pick some of that up the next time I'm at FGCI.
22-2 Rebuilds
