Gallery
Gallery
Electrical
Windlass runs slow then stops
Topic: Windlass runs slow then stops (Read 493 times)
April 11, 2018, 02:02:12 PM
Read 493 times
KenO250explorer
April 11, 2018, 02:02:12 PM »
Team, on my 2004 250 Exp, the windlass runs normal paying out line, when retrieving will run full bore for a few seconds, then slow / stop - need to feed in by hand and continually flip the switch up and down until it is in. I have checked and cleaned the connections at the switch, the dashboard mounted breaker / fuse, but cannot figure out how to check the connections at the windlass itself - or any other area I should be checking - thoughts? Thanks in advance
April 11, 2018, 04:27:52 PM
Re: Windlass runs slow then stops
April 11, 2018, 04:27:52 PM »
There should be a box with some heavy relays in it somewhere - called a "Contactor". The Contactors might be out in the open in the rear of the boat, in cabinet. They probably ran 4ag or 2 ga up to the front from the back. I stuffed my Contactor box up in the cabin, ran heavy wire to it from the rear batts and ran short heavy wire to the windlass. The switch triggers the Contactors via light wire and the Contactors do the heavy lifting via heavy wire.
I think you might have some corrosion on the Contactor.
I have a topic on how I installed mine but Photobucket trashed the pics. I'll have to upload them to fix the thread.
April 11, 2018, 06:45:06 PM
April 11, 2018, 06:45:06 PM »
Ok, all repaired - my picture repair starts on page 3 but there is some good data from the start.
https://classicaquasport.com/smf/index.php?topic=8021.0
April 12, 2018, 08:19:30 AM
KenO250explorer
April 12, 2018, 08:19:30 AM »
Thanks Rick!!! Great Pic's, when I pull the boat out of winter storage (yes, a northeasterner for now), in a week or so, I'll go on a treasure hunt for the contactor and LUK what I find. I'm pretty sure it's a factory install, so I would hope it's in an obvious place.
B/R
Ken O
April 12, 2018, 12:58:02 PM
April 12, 2018, 12:58:02 PM »
I agree. I'd get a look at the contactor. Once you find it an easy test would be to simply reverse the positive leads going to the windlass at the contactor. Basically this will make up down and down up. If the problem switches over to down then you know it's the contactor... if it stays the same then it's the windlass or the wires feeding it.
May 17, 2018, 08:31:12 AM
KenO250explorer
May 17, 2018, 08:31:12 AM »
Folks - still on the treasure hunt - haven't found the contactor yet - as it was a factory install, does anyone have breadcrumbs as to where it might be located?
May 17, 2018, 03:02:48 PM
May 17, 2018, 03:02:48 PM »
Follow the big cables. Ideally they are as close as possible to the windlass. Either in the rope locker area or somewhere along the starboard side.. I'd bet it's somewhere behind the starboard aft cabin wall. Remove the cover that is behind the helm and then remove the bulkhead panel to the left of the sink. (looking at the aft wall in the cabin)
May 18, 2018, 08:10:51 AM
KenO250explorer
May 18, 2018, 08:10:51 AM »
thanks
Electrical
