Back in the day, I'm talking 60's now, before fuel tanks were ever under the floor, the common mounting location was vertically mounted saddle tanks under each gunnel. I'm sure you could have some narrow profile custom tanks fabricated and easily add another 50 gallons (25 X 2). With the correct fuel shut off valves you could select to have them gravity feed into the main under deck fuel tank after you have run low in the main tank <50 gallons to keep from over filling the main tank and just run the engines from your current main tank so you don't have to add any additional engine fuel lines. You would need to add additional gunnel fills for each tank and possibly you could tie into the current main tank vent system but I haven't conceived what that might look like. Just an idea to keep from cutting the floor or loosing a storage locker for the extra capacity.
