Electronics
Lurking over, now for the first question. Garmin Install
Topic: Lurking over, now for the first question. Garmin Install (Read 957 times)
March 06, 2014, 02:55:03 PM
Read 957 times
johnmkar
March 06, 2014, 02:55:03 PM »
Hi,
I purchased my first Aquasport, a 1999 215 DC, late last fall
. Since then I've been lurking around the forums reading and learning. I've purchased a Garmin 740s to upgrade the electronics and I am going to be installing a B60 thru-hull transducer.But the one thing I can't find anything out about is the hull construction. I know that some earlier boats have cored hulls and at some point they are non-cored. Before I drill the wrong size hole, can someone answer the hull construction question?
Thanks for everyone's help in advance and I hope I can return the help in the future.
March 06, 2014, 03:38:47 PM
Bergertime
Re: Lurking over, now for the first question.
March 06, 2014, 03:38:47 PM »
I just put a B60 in my 98 Osprey a week ago. Mine was NOT cored. I would bet yours is not either. I am sure Bob will come by and put this to rest. See the below thread, hope it helps. Feel free to PM or post here or at the sister site if you have any ?s. I''ll be happy to help any way I can.
PS- Is a two person job, at least at the end when it gets to the tightening part. Good Luck.
http://classicaquasport.com/smf/index.php?topic=11690.0
B
98 245 Osprey / Johnson 225
March 06, 2014, 09:06:40 PM
March 06, 2014, 09:06:40 PM »
Though it was produced in 1991, my hull was not cored either. It was however produced at the same plant as your hull and BT's.
Just a thought.
March 06, 2014, 09:11:19 PM
Purgatory
March 06, 2014, 09:11:19 PM »
CB, wondering which hulls (running surfaces) were cored in the AS line? Thanks
March 06, 2014, 09:15:28 PM
March 06, 2014, 09:15:28 PM »
I can't say I have ever seen a Hialeah hull that was cored and the same for the Genmars but SB is the authority on those.
He's drilled enough holes to know for sure but as stated, we definitely know of two Gens that are solid.
Yo Bob, ya sleepin'???
March 06, 2014, 09:24:49 PM
Purgatory
March 06, 2014, 09:24:49 PM »
Yep, my thinking too. They were cored on the deck, hatches, bulkheads, etc.....but not on the running surface. The hulls were solid glass across the line...consistent layup schedule per each model.
March 06, 2014, 10:52:01 PM
Rigging Master
March 06, 2014, 10:52:01 PM »
No Genmar, or for that matter, Hialeah hulls were cored. Cored hull bottoms are quite the rarity, although I have seen 1...yes, 1. And the coring was so full of water...well, it took a few days to stop weeping.
Aquasport hulls, Sarasota or Hialeah, are solid glass. Where some people get confused is where a hull may have a stringer grid or liner that is bonded to the hull bottom...with Plexus or some other methacrylate adhesive. This is not "coring". Although I don't know the ability of a shoot-through ducer to deal with "adhesive", I would remove it before installing a P69 or other model shoot-through.
The B60 t/hull ducer? No prob as you are going through the entire sandwich of construction. But one thing you want to be certain of. The deadrise of the inner liner is the same as the hull bottom, or else the backing nut wont sit flush when tightened down. Do a test fit first, before applying all that wonderful 5200...
March 06, 2014, 10:53:25 PM
Rigging Master
March 06, 2014, 10:53:25 PM »
Bob, I am "busy". Plus the wireless out in the shop isn't behaving very nicely tonight... :x
March 07, 2014, 01:48:50 PM
johnmkar
March 07, 2014, 01:48:50 PM »
Thanks for all the feedback. I feel more confident now drilling the hull.
Now all I need is warm weather and no snow.
April 11, 2017, 04:17:53 AM
DOCREED
Re: Lurking over, now for the first question. Garmin Install
April 11, 2017, 04:17:53 AM »
As good as 5200 is, if the ducer ever has to be removed---grab the sawsall. They make another sealant that works just as well but is easier to work with.
89 250 CCP
full transom
Twin Merc 150\'s......thirsty? YES they are.
Electronics
