Controls, Steering, and Trim Tabs
19 6 throttle/shift cable lengths?
Topic: 19 6 throttle/shift cable lengths? (Read 1068 times)
February 21, 2014, 11:06:11 AM
Read 1068 times
aquaprouts
February 21, 2014, 11:06:11 AM »
can any 19 6 experts tell me the length of these cables from console to engine, running through the floor channel?.....the ones on the boat now are running from the console, directly to the motor across the top of the floor(previous owner replaced motor on boat and used the new motors cables and side mount remote control, so I cant go by their length).....thnx!
February 21, 2014, 12:01:05 PM
Rigging Master
Re: 19 6 throttle/shift cable lengths?
February 21, 2014, 12:01:05 PM »
I'd be willing to bet 20 footers. 3' from the binnacle to the rigging trough, 3' from the console to the turn in the trough aft, 8' back to the starboard corner, then another 6' to make the turn to the motor and have a nice loop before entering the lower pan...
February 21, 2014, 03:11:36 PM
February 21, 2014, 03:11:36 PM »
i am about 93.5 % sure i had 18 footers in my 200 osprey
1996 200 Osprey
SOLD
1968 22-2 Flatback
SOLD
1993 210 Explorer
SOLD
1991 Fountain 31TE
SOLD
1989 Fountain 12-meter
SOLD
1992 Talon F-20
SOLD
February 21, 2014, 07:51:52 PM
saltfly
February 21, 2014, 07:51:52 PM »
I have 20 footers on my 19-6.
February 21, 2014, 09:47:48 PM
gman 82 aquasport
February 21, 2014, 09:47:48 PM »
My 82 19-6 's cables measured out at 18 feet, when I rebuilt the floor and put the cables in a tube out the console floor and under the floor to the starboard stern side exit then to the motor they just barely made it...they were plenty long while in the trough...
1982 19-6 Osprey
1992 Johnson 150
"THERAPY"
Member # 2331
February 23, 2014, 08:56:06 AM
Georgie
Mechanical Master
February 23, 2014, 08:56:06 AM »
I'd bet the extra 2 ft from 18-20 would help to make the turn outside the console and into the back of the the side mount controls. Binnacle style bottom-mount controls inside the console would be a slightly shorter run.
Ryan
1979 246 CCC
1987 Wellcraft 18 Fisherman
February 23, 2014, 09:26:44 AM
Rigging Master
February 23, 2014, 09:26:44 AM »
The key to this little discussion is you DON'T want to have cables that are too short, or "marginal". Remember, the cable stretcher and the wire stretcher are ALWAYS checked out of the tool crib when you go to get them...
February 23, 2014, 04:16:59 PM
aquaprouts
February 23, 2014, 04:16:59 PM »
thnx for the input.....looks like i should go with the 20 footers to be safe
