Author Topic: 1980 family fisherman repower  (Read 1291 times)
August 29, 2013, 09:00:42 PM
Read 1291 times
3xlski
« on: August 29, 2013, 09:00:42 PM »
Just wanted some info on re-powering my 80 FF it had a 175 Evinrude but previous owner took it off because he blew it. would a 150 be under powering it. thanks for any input
August 29, 2013, 09:17:46 PM
Capt Matt
Re: 1980 family fisherman repower
« Reply #1 on: August 29, 2013, 09:17:46 PM »
A newer 150 would be perfect, as much power as a old 175
Capt Matt
Light tackle sportfishing
August 29, 2013, 09:24:07 PM
« Reply #2 on: August 29, 2013, 09:24:07 PM »
I'm guessin' it's a 22 FF.
If so max hp is 245 like the CCP of that era. In 84 mine came with a 185. I re-powered with a 200 and that's pretty much the hp of choice for those size hulls. Again, if it's a 22, then your listed weight is 2200lbs (like the CCP) and rated at 245 hp. I'm thinking a 40hp would move it around but something along the lines of a newer 175 or and older 200 is the ticket.
What is the year and make of the 150?
August 29, 2013, 09:42:22 PM
3xlski
« Reply #3 on: August 29, 2013, 09:42:22 PM »
Thanks Matt & Bob for the replys. Its a 1980 22' FF in real good shape I found a couple of 1989 150's but i dont want to be under powered. I started out on here with a 73 222 CC with a 1985 evinrude 115 and she ran great so i want to be just as happy with this one
August 29, 2013, 09:45:07 PM
3xlski
« Reply #4 on: August 29, 2013, 09:45:07 PM »
Oh and they were Evinrude's and johnson's thats what was on it
August 30, 2013, 09:18:20 AM
Curious
« Reply #5 on: August 30, 2013, 09:18:20 AM »
Mine is a 78 22FF with the modified V.  I have a 96 Yamaha 200 SW series and it is a great match.  However, I'm sure a 150 would push it fine.  You'd probably get a top end of about 36mph.  If you do a search, someone on here repowered with a 150 if I recall.  Those new 200 inline 4 cylinders from Yamaha would be sweet on this boat.
Dan
1978 22 Family Fisherman
1996 Yamaha 200 SW Series
August 30, 2013, 11:51:40 AM
bondobill
  • West Coast
« Reply #6 on: August 30, 2013, 11:51:40 AM »
If it's a deep vee I would try to go with a 200.
I run about 30 mph at 4000 rpms. Get a top end of close to 42 mph.
Had a 225 on my 79 222 FF before the  200 I got now.
Numbers where about the same.
Bill
1979 222 FF
- Winston Churchill
Bill
August 31, 2013, 01:57:55 PM
3xlski
« Reply #7 on: August 31, 2013, 01:57:55 PM »
I found a 1994 evinrude 200 totally rebuilt its a looper engine whatever that is. Is this a good motor?
August 31, 2013, 04:14:44 PM
FJStretch
« Reply #8 on: August 31, 2013, 04:14:44 PM »
A "looper" is a 2-cycle engine. It's just slang.
FJ Stretch (Member #3324)
1986 Aquasport Osprey 200
August 31, 2013, 05:53:13 PM
« Reply #9 on: August 31, 2013, 05:53:13 PM »
A looper is a loop charged two stroke OMC motor. It has to do with how the intake charge is drawn into the cylinder. Not all two stroke OMC are looped charged some of them are cross flow induction. Generally the crossflow motors idle better and run better at low rpms. Loopers don't idle as good but usually have more power at high rpms.
August 31, 2013, 06:04:53 PM
3xlski
« Reply #10 on: August 31, 2013, 06:04:53 PM »
Thank you guys for all your help. I don't know that much about outboards I'm normally an inboard guy. Is there a difference between an ocean pro and an ocean runner and just a 94 200 HP evinrude
September 01, 2013, 12:26:06 AM
FJStretch
« Reply #11 on: September 01, 2013, 12:26:06 AM »
Hat tip to Wingtime... I didn't know that.
September 02, 2013, 09:51:45 PM
« Reply #12 on: September 02, 2013, 09:51:45 PM »
Quote from: "3xlski"
OPs are Evinrude's nomenclature while ORs was Johnson's for their respective saltwater series engines. Think more stainless parts.
September 02, 2013, 10:32:21 PM
3xlski
« Reply #13 on: September 02, 2013, 10:32:21 PM »
Thank you capt bob for the info. Everybody on here is a real help and not to mention all the rebuilds are amazing thanks again, Ted
September 04, 2013, 02:20:47 PM
dburr
« Reply #14 on: September 04, 2013, 02:20:47 PM »
Quote from: "wingtime"
To further expand, there is a difference in the shape of the piston crown.  Typical 2 stroke motor has intake and exhaust ports machined into the lower part of the cylinder walls.  As the piston travels up and down the skirt covers and uncovers the ports to allow for the exhaust purge/aircharge to happen.  The result is that at one point in the cycle (piston traveling through bottom center) both ports are open.  The air charge that has built up pressure in the crank case due to the piston displacing the volume from the roughly top center intake volume to bottom center rushes into the cylinder under pressure while the expended exhaust gas is still going out the exhaust port.  With a typical flat top 2 stroke piston shape a slug of the air fuel charge mix goes right out the exhaust port  and some of the exhaust gas is trapped in the top of the cylinder...  Not the most efficient mix..
To keep our hard earned and payed for fuel in the cylinder and to get a better exhaust purge during this  evolution, some old boy way smarter then me decided to put a funky ramp shape on the piston head to keep the air/fuel charge from blasting straight across the piston and out the exhaust port.  The ports were modified in some cases too with an appropriate angle to further direct the airflow in the direction it needs to go..   Damn genius I think..  The charge would now be directed up to the top of the cylinder to displace the rest of the exhaust gases and keep the fuel mix where it was supposed to be, next to the plug waiting to go boom...  Hence the loop charged motor was born.. :cheers:
Dave
88 222 Osprey
00 Yamaha OX66 150
CAS # 2590
