Gallery
Gallery
22-2 Rebuilds
1977 22 -2 rebuild
7
Topic: 1977 22 -2 rebuild (Read 5952 times)
June 19, 2015, 03:49:44 PM
northfork
Re: 1977 22 -2 rebuild
Reply #15 on:
June 19, 2015, 03:49:44 PM »
I am using 1708 with mat sewn in. I was just using the extra layer of mat between to help with the bond. It really smoooths over all small imperfections.
June 19, 2015, 05:55:40 PM
Reply #16 on:
June 19, 2015, 05:55:40 PM »
One of the tips Eugene Sun gave me was to always use a layer of mat between new 1708 and old/cured fiberglass, as it does improve the bond strength as north said. I'm not sure it's necessary between successive layers of 1708, especially if they are added wet-on-wet, but they can't hurt. Looking good, north!
June 19, 2015, 09:53:11 PM
Que Pasa
NorthEast
Reply #17 on:
June 19, 2015, 09:53:11 PM »
Nice work North.
June 22, 2015, 10:21:30 AM
northfork
Reply #18 on:
June 22, 2015, 10:21:30 AM »
The top edge of the skin cut.
Blue water bonded to skin
transom crown. I'm happy with the curve.
June 22, 2015, 10:55:31 AM
Reply #19 on:
June 22, 2015, 10:55:31 AM »
Nice job
What does the Bluewater weigh? Looks beefy.
June 22, 2015, 10:57:00 AM
Que Pasa
NorthEast
Reply #20 on:
June 22, 2015, 10:57:00 AM »
The skin cut looks super clean, how did you cut the radius.
June 22, 2015, 01:10:06 PM
northfork
Reply #21 on:
June 22, 2015, 01:10:06 PM »
It is probably less than two sheets of 3/4" plywood. It is some cool stuff. Cuts nice and easy and seems super strong.
Chuck
June 22, 2015, 01:14:33 PM
northfork
Reply #22 on:
June 22, 2015, 01:14:33 PM »
Que
The radius cut can easily be done with a circular saw. Mark a sharp line and take your time. That how I cut the 1 1/2" thick transom as well. It is not a tight radius.
I will let you know the ht of the crown tonight.
Chuck
June 22, 2015, 01:49:31 PM
Callyb
MidWest
Reply #23 on:
June 22, 2015, 01:49:31 PM »
Looks great!
Mighty fine work Chuck.
Carl
___________________________
June 22, 2015, 09:41:07 PM
northfork
Reply #24 on:
June 22, 2015, 09:41:07 PM »
Thanks Carl
I am figuring things out as I go. Any suggestions are more then welcome.
June 23, 2015, 10:41:47 AM
northfork
Reply #25 on:
June 23, 2015, 10:41:47 AM »
Took all the bolts and bracing off last night. The transom feels so solid with the Coosa even without knees. That stuff is really cool.
June 23, 2015, 05:41:54 PM
northfork
Reply #26 on:
June 23, 2015, 05:41:54 PM »
time to clean the shop
June 25, 2015, 11:14:51 AM
northfork
Reply #27 on:
June 25, 2015, 11:14:51 AM »
fillets done. a little sanding then some glass on the transom.
June 25, 2015, 11:51:33 AM
Reply #28 on:
June 25, 2015, 11:51:33 AM »
Looks good.
Going forward, if you can work it out where you spread the fillets, let them start to cure enough that you won't push them out of place but they're still "green", then lay your tabs wet on wet over them, it'll save you the sanding in between. I learned that the hard way too.
June 25, 2015, 02:51:37 PM
northfork
Reply #29 on:
June 25, 2015, 02:51:37 PM »
I started to do that. I spent to much time working the fillets and they were kicking off. I had to many rough spots to lay over at that point. I thought better to take my time and sand then tab. Whats a couple of hours sanding at this point.
Chuck
7
22-2 Rebuilds
1977 22 -2 rebuild
