Aquasport Discussion
175 Osprey w/115 Etech
Topic: 175 Osprey w/115 Etech (Read 544 times)
February 05, 2016, 11:56:52 AM
Read 544 times
Sportfish50
February 05, 2016, 11:56:52 AM »
Is a 175 Osprey with a 115 Evinrude etech still self-bailing with that much weight on the back and also does water come over the transom when you suddenly stop?
February 05, 2016, 04:22:09 PM
akbridge
Re: 175 Osprey w/115 Etech
February 05, 2016, 04:22:09 PM »
I have a 90 etec with a jack plate on the back of my 170. The weights should be similar. It is not self bailing. But I have not had water over the transom when coming off a plane. Most of the 170's are not self bailing at this point. The foam tends to absorb water and make the boat heavier. Also we are putting bigger, heavier engines on these boats beyond what they were originally designed for. Having said that your boat should be a rocket ship with a 115 on the back!
February 05, 2016, 07:30:38 PM
BMAC1988
February 05, 2016, 07:30:38 PM »
subscribed.... ive got a Suzuki DF 140 4stroke in the works to go on the back of my 175 to replace the 88SPl on there now. should be a little over 100lbs heavier. im also going to be installing a CMC jack plate which is another 30lbs or so as well has another 5" of setback.
im going to see what its like but ive already been kicking around the idea of adding a weight offset flotation box to attach to the transom.
Brett
95 OSPREY 175, Suzuki Df140, CMC High Speed Jack-Plate, Baystar hydraulic steering, Standard Horizon VHF, Digital Antenna, Dual GARMIN 541S, BENNETT Tabs, S&E Customs Leaning Post, Dual Batteries, T-Top,
February 06, 2016, 08:25:46 AM
Sportfish50
February 06, 2016, 08:25:46 AM »
Thank you so much for your responses. I am going to test drive it today.
February 06, 2016, 08:27:20 AM
BMAC1988
February 06, 2016, 08:27:20 AM »
If you can snap a couple pics of it sitting in the water and where the scuppers are
Brett
February 12, 2016, 11:28:42 PM
Sportfish50
February 12, 2016, 11:28:42 PM »
I test drove the boat and bought it. It is a 50 mph missle. It is not self bailing unfortunately as the motor weight pushes it down a little too far. I did not get a chance to tie it up and see if it would self bail without me onboard. I will do that soon and post pictures for your enjoyment. Ia m taking my leaning post out of my 17 Mako and swaping the cooler bench seat out of the Aquasport.
Lots of things to fix but the transom passed the rubber mallot test and there are no soft spots in the deck. Think I got a good deal for a 97 hull with a 2012 etec and alum trailer. Only 46 hours on the motor.
February 12, 2016, 11:35:29 PM
Sportfish50
February 12, 2016, 11:35:29 PM »
The new addition, Senor Moment!
February 13, 2016, 07:12:31 AM
February 13, 2016, 07:12:31 AM »
Congrats on the new family member - looks clean without all the graphics. Now you can paint it any color you want
http://www.classicaquasport.com/gallery/showphoto.php?photo=5737&title=1997-catalog-pg19&cat=629
February 14, 2016, 06:44:14 PM
BMAC1988
February 14, 2016, 06:44:14 PM »
you have any pics of it in the water? im anxious to see how low it sits. also you have me worried if that 115 pushes it 50, my 140 oughta be outright scarey.
Brett
