Author Topic: '76 22 Osprey re-build  (Read 19881 times)
May 25, 2015, 09:02:25 PM
Reply #30
Que Pasa
  • NorthEast
Re: '76 22 Future re-build
« Reply #30 on: May 25, 2015, 09:02:25 PM »
Ugg, just found three holes in the forward hull. Looks like the boats been on the rocks. Hidden under bottom paint with a :*: patch job. In it pretty deep.
May 26, 2015, 04:59:18 AM
Reply #31
« Reply #31 on: May 26, 2015, 04:59:18 AM »
Bottom paint hides a lot of stuff  :roll:
May 26, 2015, 04:23:56 PM
Reply #32
Que Pasa
  • NorthEast
« Reply #32 on: May 26, 2015, 04:23:56 PM »
Got into it with the grinder today gonna take some pics, will post later. Can't really tell what I'm looking at besides it going through the gel. Dunno if this guy just was patch happy and I'm grinding original glass or if it went through all the way. The resin and glass seem pretty solid. Let the itching begin.
May 26, 2015, 04:50:13 PM
Reply #33
Que Pasa
  • NorthEast
« Reply #33 on: May 26, 2015, 04:50:13 PM »
In this one you can see the patch above where I did the grinding
And this one you can see it below.
May 26, 2015, 06:09:17 PM
Reply #34
« Reply #34 on: May 26, 2015, 06:09:17 PM »
The top pic looks like there is a repair but the others look normal.  You may want to grind back along the keel, towards the front, an equal amount on each side and plan to put a layer or two of 1208 along the keel or maybe 6oz mat/cloth.
Welcome to the grinding brigade.  :salut2:
May 26, 2015, 07:43:16 PM
Reply #35
Que Pasa
  • NorthEast
« Reply #35 on: May 26, 2015, 07:43:16 PM »
They are all repairs Rick, but I'm wondering if this guy chipped the gel with the trailer and then just slapped glass on there. Look at the middle pic you'll see a patch under the bottom paint as you go up the keel toward the middle of the pic.
May 27, 2015, 04:39:22 AM
Reply #36
« Reply #36 on: May 27, 2015, 04:39:22 AM »
It's hard to tell from the pics - if you're talking about the white, looks like gelcoat from here.
May 27, 2015, 06:10:27 AM
Reply #37
Que Pasa
  • NorthEast
« Reply #37 on: May 27, 2015, 06:10:27 AM »
No, you can see the raised edge under the bottom paint.
May 27, 2015, 06:29:23 AM
Reply #38
Que Pasa
  • NorthEast
« Reply #38 on: May 27, 2015, 06:29:23 AM »
You can see where the yellowing that is under the bottom paint in this one. that's what it looked like when I started grinding, well I'll know soon enough as the deck is coming off today.
May 27, 2015, 09:08:52 AM
Reply #39
« Reply #39 on: May 27, 2015, 09:08:52 AM »
Much easier to see when you draw arrows to it  :old01:
 :laugh03:
We'll be waiting to see what it looks like inside.
May 28, 2015, 11:39:32 AM
Reply #40
Que Pasa
  • NorthEast
« Reply #40 on: May 28, 2015, 11:39:32 AM »
Well good news my floor is dry, bad news foam on starboard side is wet. Hate to cut out a good floor but gotta get the wet stuff out.
May 30, 2015, 07:00:25 PM
Reply #41
Que Pasa
  • NorthEast
Re: '76 22 re-build
« Reply #41 on: May 30, 2015, 07:00:25 PM »
Need a little advise, when I construct my transom, do I put the cap on top of the transom edge, or do I tie into the the transom with the edge of the cap.
May 30, 2015, 07:27:34 PM
Reply #42
« Reply #42 on: May 30, 2015, 07:27:34 PM »
I laid the cap back on top of my transom and tied it in.
Are you asking if you need to cut the cap to get to the transom?
May 30, 2015, 07:36:43 PM
Reply #43
Que Pasa
  • NorthEast
« Reply #43 on: May 30, 2015, 07:36:43 PM »
 I am enclosing the transom and capping it. I think you didn't enclose yours if I'm not mistaken. I will be using wood and putting a slight crown in the transom cap. So do I attach the cap to the transom or vice vs.
May 30, 2015, 07:57:01 PM
Reply #44
Callyb
  • MidWest
« Reply #44 on: May 30, 2015, 07:57:01 PM »
Tie it in. you can either leave the core low enough to use as a shelf (I will go out to the shop and get a picture for you) or glue cleats to attach your cap into the hull.
Carl
___________________________
