Fuel Vent Question
Topic: Fuel Vent Question (Read 759 times)
May 13, 2019, 06:31:32 PM
Read 759 times
xavier
Fuel Vent Question
May 13, 2019, 06:31:32 PM »
I have a 1984 170 with a new 2017 90 Suzuki. I recently was filling my gas tank using 5 gallon tanks I had filled up at gas station. The boat was attached to my truck. The fuel usually flows out of the vent when full. This time the gas came all the way up the fill hole,but did not flow out of vent. After driving with the boat on trailer I noticed the fuel draining out of vent down side of hull. The gas gauge read it was 3/4 full but not sure if I can rely on the accuracy of gas gauge all the time. Anybody had this happen or can weigh in on what I should do if anything?
Thanks!
May 14, 2019, 02:18:29 PM
Re: Fuel Vent Question
May 14, 2019, 02:18:29 PM »
Check your vent for mud dauber nests - pretty common.
May 14, 2019, 05:36:02 PM
xavier
May 14, 2019, 05:36:02 PM »
Ok thanks will do.
May 15, 2019, 11:20:14 PM
boatnamesue
Jason
May 15, 2019, 11:20:14 PM »
When filling by gas can versus pump, using the latter flows fuel into tank with significantly more force causing the pressure building in the tank to release via vent. Filling by can is passive thus much less pressure needing release.
Feul gauge reading wrong level is separate from above. Check sender continuity. If good, check sender float isn't sticking. If not, replace.
Jason
1976 AS 170
1998 S115TLRW
May 24, 2019, 10:36:29 AM
Blue Agave
May 24, 2019, 10:36:29 AM »
How old is the vent? Is it original? If so, go ahead and replace the vent.
3.0 EFI Mercury 150 4S
May 28, 2019, 09:17:41 PM
xavier
May 28, 2019, 09:17:41 PM »
Thanks, for the advice. The vent is original. I will check into the the other items and fill it up at the gas station and see if that makes a difference. I also think the gauge wire needs to be replaced. When I open port and move the wire that attaches to fuel tank the gage jumps around.
June 17, 2019, 06:49:32 PM
xavier
June 17, 2019, 06:49:32 PM »
I was told it could be the fuel fill hose holding gas not sure how that happens?
Fuel Vent Question
