200 CCP Rebuilds
New to Me 1979 20 CCP
26
27
28
29
32
Topic: New to Me 1979 20 CCP (Read 32159 times)
June 04, 2019, 07:38:22 PM
Reply #390
Re: New to Me 1979 20 CCP
Reply #390 on:
June 04, 2019, 07:38:22 PM »
Did you mask off the hull sides and drop-cloth the inside? Maybe a HVLP setup?
June 05, 2019, 06:05:07 AM
Reply #391
Reply #391 on:
June 05, 2019, 06:05:07 AM »
Quote from: RickK on June 04, 2019, 07:38:22 PM
Yes, I used tape and drape to bask off the hull sides and masking paper on the inside. I used the Harbor Freight purple HPLV gun.
June 05, 2019, 05:32:30 PM
Reply #392
Reply #392 on:
June 05, 2019, 05:32:30 PM »
I think I have a couple of those - works.
June 09, 2019, 05:22:34 PM
Reply #393
Reply #393 on:
June 09, 2019, 05:22:34 PM »
Yesterday, I lined up some help, and we hung the Armstrong Bracket and loaded the console and leaning post. Today, I dry fit the console and leaning post before over drilling the screw holes, routing out some of the foam core and filled with thickened epoxy. About half the console will be through-bolted with #14 screws into epoxy plugs for the remainder of the console and leaning post. Everything will be bonded with methacrylate adhesive. I think it will be rock-solid.
June 09, 2019, 06:19:47 PM
Reply #394
Reply #394 on:
June 09, 2019, 06:19:47 PM »
Coming together fast now and looking good
June 10, 2019, 01:06:13 PM
Reply #395
Reply #395 on:
June 10, 2019, 01:06:13 PM »
Looks great. It's gotta be exciting for you to see it all coming together!
June 13, 2019, 03:59:54 PM
Reply #396
Reply #396 on:
June 13, 2019, 03:59:54 PM »
The console and leaning post are permanently part of the CCP. They're bonded in with Methacrylate adhesive along with bolts and screws. I had to work around the weather today, but I got the nonskid painted on my cap. It's Soft Sand Rubber particles mixed into the same Quantum polyurethane top coat that I used on the boat. I used 2 oz of particles (3pts fine to 1pt medium) mixed into 16oz mixed paint and a foam roller to apply. It turned out pretty good.
June 14, 2019, 01:09:17 PM
Reply #397
Reply #397 on:
June 14, 2019, 01:09:17 PM »
Check !
The list is getting smaller
June 17, 2019, 04:59:24 PM
Reply #398
Reply #398 on:
June 17, 2019, 04:59:24 PM »
The mission is coming into focus. I dry fit the aft and spring like cleats along with rod holders in the cap. I have four 30 degree holders along the rear cap for flatlines/downrigger rods, two more further forward for long and short outriggers and four 15 degrees in the bow. After seeing the rod holders in the bow, I think I'll add two more. They'll need to be 0 degree because that's all that will fit.
June 17, 2019, 07:17:31 PM
Reply #399
dirtwheelsfl
Reply #399 on:
June 17, 2019, 07:17:31 PM »
Now the fun starts
Liking the color choice
June 17, 2019, 09:14:14 PM
Reply #400
Reply #400 on:
June 17, 2019, 09:14:14 PM »
You can never have too many rod holders!
June 23, 2019, 05:56:47 PM
Reply #401
Reply #401 on:
June 23, 2019, 05:56:47 PM »
I went to work on the last major fairing project on the boat. I'll still need to fair my coffin box, but I can work on that off the boat while my motor is being rigged. I had some epoxy and a bunch of micro-balloons, so I went with a home brew for this one.
She's sanded down reasonably fair. I still need to give it a once over, and fair in a good transition for the hatch rims, but I'll be applying primer and non-skid soon.
June 29, 2019, 08:01:48 AM
Reply #402
Reply #402 on:
June 29, 2019, 08:01:48 AM »
Still chipping away at her. Primer is on the deck. I hope to spray the gloss rings around my hatches on Sunday and have the nonskid down Monday.
June 29, 2019, 08:55:19 PM
Reply #403
Reply #403 on:
June 29, 2019, 08:55:19 PM »
July 05, 2019, 08:29:51 PM
Reply #404
Reply #404 on:
July 05, 2019, 08:29:51 PM »
It's amazing how long things take. I think, I'll sand and then I'll mask, or I'll mask and then I'll paint, and the boat gods reach down and slap me. One day to sand, one day to mask, one day too spray the gloss rings, one day to mask for the non skid, and then one day to roll on non-skid, anyway all those days add up to non-skid is finished on the cockpit sole.
26
27
28
29
32
200 CCP Rebuilds
