Man, I had convinced myself that I wanted white. Now you've got me thinking about gray again. I watched a Youtube video of the installation of a white on white rubrail on an older seacraft. I thought it looked pretty classy. I imagine you've seen both colors. If it was you, what would you go with?
You've got the same boat as my brother, about the same year too. His has the problem much worse than me. At least a foot on both sides. Mine is only about 4 or 5 inches on each side. Not terrible, but annoying none the less.
I still do have a contact at Taco, but they are not making the gray insert anymore. So it's white or black if you want to replace...
Quote from: "seabob4"I still do have a contact at Taco, but they are not making the gray insert anymore. So it's white or black if you want to replace...I would like to do the black insert.Can you hook me up with your guy Bob?Thanks Bryan
Rope an option? My last boat had a rope rub rail insert that I actually really liked the look of (can't speak to its function vs rubber/plastic/vinyl).
