Quote from: "Rhojo" so if we shouldn't use a float switch (i've noticed mine is acting up) what do we use?Rule 51S auto bilge pump. This model is rated at 1500 gph.http://www.google.com/search?q=rule+51s ... =firefox-a
Mr. Green at work inside that switch..., voltage, but no current flow.
Well what say ye about the computer switched model as opposed to the mechanical switched type. I really don't know how long that type pump has been on the market.Logic would dictate you would not want a "computer" in a bilge but if properly sealed, who knows (and that's the question).Battery drain aside, maybe the constant start and stop adds to its longevity.?
Scott, you what's funny, I guess? I've never watched ShipShape...
Guys, I'm not saying don't use a float switch, quite the contrary, you MUST! Even boats moored on a trailer, drains clog up with God knows whatever, and now the bilge starts filling up with water with no way to turn on the pump if you're not on board...My point is that a lot of people like to use these Rule-Mate pumps with the built-in float, a sort of all in one. What I see in pumps and floats is that the pumps last a HELL of a long time, it's the switches that crap out more frequently.
Quote from: "flounderpounder225"Mr. Green at work inside that switch..., voltage, but no current flow.Yep. Mr. Green will get you on most any wiring on a boat, especially battery cables.After getting tired of changing float switches I started sawing them open to see what the trouble was. I traced it down to where the wires enter. It's NOT sealed. Just the stupid rubber grommet letting water into the switch. I started daubing 5200 where the wires enter and letting it set up before installing the switch. I think the ones I have now are over 3 years old with no issues.SB, you are right on about the all-in-one units. You have to toss a good pump because of a bad switch. Nice video by the way.
